Results 1 to 20 of 20
Thread: Outdoor cooler project
    TundraMan's Avatar
    Jul 2014
    La Porte,Texas
    15
    Here is some pictures of my weekend outdoor cooler project to match the rest of my backyard.
    13K gal, IG pebble, 2 HP Jandy ePump VSD, Jandy cartridge filter, Spa, Jandy 250 btu heater, UV, Ozone, Dolphine M4 cleaner. Built in 2014
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Outdoor cooler project
    Very nice! Nice pool, nice view!
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Nice attention to detail and a most excellent backyard!
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    TundraMan's Avatar
    Jul 2014
    La Porte,Texas
    15
    Thank you!!!!
    38,262
    Wow!!! Great view and that cooler is really nice!!!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,573
    I'll take 2 please!
    Wow, looks great!
    Plano, TX
    20,000 gallons Kidney Bean IG Plaster, Pentair Clean and Clear 530 Cartridge Filter
    May 2009
    NC
    136
    Love it! I've never seen anything like that before. And your backyard looks great too!
    24' Round 52" High AG, Waterway 125 SF Pro Clean 2HP, 2 SPD Cartridge Filter
    Pool Rover Jr. /TF-100 Test Kit/ BBB - Ex Baqua User
    Oct 2014
    Central PA
    87
    ImageUploadedByTapatalk1430931510.358364.jpgImageUploadedByTapatalk1430931526.706669.jpg
    I did the same thing a month or so ago, but I used an old freezer I found on Craigslist and added a temp control sensor so it won't freeze my drinks! You did a good job!
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Nice job.
    What kind of fittings for the drain? Is the drain watertight?
    18' x 38' 20,500 gallon vinyl IGP, 3.5 - 7' depth, Pentair FNS Plus DE filter,
    2hp Whisperflo high performance pump, 1.1hp boost-rite pump for the cleaner,
    250k BTU MasterTemp heater, LetroLegend pool cleaner, Hayward TurboCell GLX-CELL-15 chlorine generator
    Speedstir, K-1776, TF-100
    DFW, TX
    24,468
    Man, that is fancy! It is my job to empty coolers, not make them.
    MrsDimples's Avatar
    Jun 2014
    England
    47
    That is NICE!
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I want one too!
    very spiffy and I dig the bamboo!
    Divin Dave,
    TundraMan's Avatar
    Jul 2014
    La Porte,Texas
    15
    Thanks everyone!!!
    I used 1/2" fittings for the drain setup.
    I purchased this http://m.homedepot.com/p/Halex-1-2-i...1631/100129507
    Plus 1/2" nipple and 1/2" female connection spigot. All is water tight.
    Dec 2014
    Cypress, Texas
    200
    TundraMan, I like the cooler, but I also like the pool, what are the dimensions?
    TundraMan's Avatar
    Jul 2014
    La Porte,Texas
    15
    Thank you, inside dimensions are 14' x 32'
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Nice work on the coolers.
    Quote Originally Posted by pooldv
    Roger that!
    Jun 2015
    Haughton, Louisiana
    50
    I'll be stealing this, awesome job
    24" Round Above Ground 14000 Gallons, Pentair Sand Dollar Filter, 1.5 HP Pump, K-2006 test kit
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Where do I place my order??? Love it!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
  20. Back To Top    #20
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    love it!!! i bet u saw that on pinterest because i want to do the same thing!!!
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
