Results 1 to 10 of 10
Thread: Hayward Salt Generator
    Apr 2015
    Houston Texas
    4
    Is there a way to test my T9 cell?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hayward Salt Generator
    Welcome to TFP!
    The easiest way is to collect a water sample directly from a return while the cell is running. Test that for chlorine level compared to the chlorine level in the pool. You'll also want to verify that you have sufficient salt before condemning the cell.
    Apr 2015
    Houston Texas
    4
    My salt reading was at 1500ppm and I added 5 bags and it went up to 2000ppm I took a sample to the pool store and he said it was at 4000 so I took the cell in and he said it was bad Hayward has a limited warranty and its not quit 3 yrs. yet
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by rbmorlock View Post
    Don't trust that pool store salt test. I would buy a Taylor salt test kit if you don't already have one. Their reading was double you r reading????? Something not right here.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Apr 2015
    Houston Texas
    4
    Are you talking about test strips
    38,290
    The pool store test for salt is likely ok. I prefer to do my own testing with the Taylor titration salt test, but the strips can be fine too to give you a ballpark.
    My SWG and test reading never match, but I do it more to look for trends ... like the SWG reading lower and lower, but the test staying the same.
    Jun 2011
    Long Beach, CA
    2,787
    Did the pool store hook up and test the cell with their tester? If so, it looks like the cell is worn out and needs to be replaced. One of the first indicators that a cell is nearing its end of life is a low salt reading. There are other factors that can cause a cell to read low, but if the pool store tested the cell then I would say the cell is dead.
    Apr 2015
    Houston Texas
    4
    Yes it was hooked up to a tester I bought it 7-14-12 and do you know if they will replace it or pro-rate it
    38,290
    You need to contact Hayward to find out what they will do. No sense in us speculating
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    I will find out for you if you private message your email and phone number.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
