Results 1 to 11 of 11
Thread: Booster Pump for Slide
    Apr 2013
    Oshkosh, Wisconsin
    15
    Have several questions.
    I have a 18x36 inground pool and am planning to add a slide. I realize that I need a booster pump to get the adequate pressure and gpm.
    If I add this booster pump to the 1" pool slide line I have plumbed that is a branch off of the 1 1/2" return line after leaving the heater, I want to know how to control the pump. So, the main pump needs to be on for this pump to work and I don't want the slide on all the time, so wondering how you all have done this?
    18x36 Steel Wall Vinyl Liner Pool
    Sta Rite Cartridge Filter
    1hp pump
    Raypak 260k NG Heater
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Booster Pump for Slide
    You sure you need a booster pump? I kinda doubt it...they usually don't need much water or much pressure, just enough water to wet the slide so you don't stick.
    Apr 2013
    Oshkosh, Wisconsin
    15
    Well, currently when I open the valve on the line that is plumbed to the area where the slide will go, it flows about 6" in the air. To clarify; I have this 1" pipe stubbed out of the concrete decking, from this point I will need to plumb it up 7' to the top of the slide.
    1hp pump
    Jul 2007
    Suwanee, GA
    528
    Does the slide you are purchasing have a recommended water flow? I'd check the docs for it first, that may be a good starting point. The slide we've got has a dedicated 2hp pump that pushes over 100gpm over it, but that is well more than it needs.
    The 1" pipe you've got is probably all it will need, the 7 extra feet will likely make little difference.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Apr 2013
    Oshkosh, Wisconsin
    15
    Thanks for replying all.
    This slide is a rotomolded plastic slide intended for a play set that i plan to mount to my nearby deck and run pex from the 1" pipe stub at the conc deck to the top and install some sort of fitting to spray the water.
    So, pretty much would like to have 10 gpm.
    1hp pump
    Jul 2007
    Suwanee, GA
    528
    10 gpm is probably more than enough.
    Gary
    38,521
    I think I probably have maybe 1GPM for my slide. It is an old Aqua slide I think, not like the newer ones where there is rushing water down the slide. It just needs to stay a little wet so you don't stick and anyway, everyone is already wet from the pool. Just do not go down the slide before you jump in the pool
    Apr 2013
    Oshkosh, Wisconsin
    15
    So, would I be better off looking at upgrading my current 1hp pump to a VS or 2 speed of a higher HP? If I added a 2 speed pump, would I still need to change the speed manually to high for the slide to work?
    i forgot to mention that I piped my pool with 2" pipe.
    1hp pump
    38,521
    Can you partially close the water flow to the pool which should force more water out of the slide pipe? If mine can pump to the roof, yours should pump up to slide height.
    Apr 2013
    Oshkosh, Wisconsin
    15
    I will try that and i should just run some pex tubing up to where the slide will go to test.
    I guess i have been basing my questions on the water spraying upward out of the stub only about 12" when the valve is opened?? After seeing that I was always thinking I won't have enough pressure by the time it gets piped up another 7'
    1hp pump
    Apr 2013
    Oshkosh, Wisconsin
    15
    Slide works great. I took the 3/4" water supply and split it off into 2 3/8" PEX lines and it sprays adequate enough water.
    1hp pump
