Results 1 to 8 of 8
Thread: Disable solar sensor on Aqualink
    Jul 2012
    Duluth, GA (ATL)
    121
    In my quest to find ways to use more JVAs, I want to allocate the Solar JVA to something but my iAqulink keeps telling me that the SOLAR JVA is used when I don't have it connected nor do I have a Solar temp sensor connected. How do I make the system let me use it? How do I disable this?
    Do I simple install a short jumper between the two wire ports for the solar sensor? Or do I need to maybe say enable dip switch 1 on the 2nd set (Heat Pump priority, which disables Solar Heat). Again don't have a solar sensor, only have a water sensor and an air temp sensor hooked up.
    Dixit
    Picture of Pool
    14,000 Gallon Freeform Plaster based pool. 1,000 Gallon Spa with Spillage Basin. Jandy Aquapure Ei Salt Water Chlorine Generator. Jandy CL580 Cartridge Filter. Sta-Rite P6E6G-208L Filter Pump. Jandy JHP2.0 Spillage Pump. Jandy LX400 Heater. Caretaker 99 Floor cleaner. Polaris Leaf-B-Gone. iAqualink.
    Jul 2012
    Duluth, GA (ATL)
    121
    Re: Disable solar sensor on Aqualink
    Ok so setting the 2nd set first dipswitch to ON for heat pump priority didn't work, it still thinks Solar is USED. In the sensors it shows OPENED. Not sure how to get the system to think its disabled so I can use the Solar JVA port as the manual states it can be used for other things if there is no solar sensor, which is what I have (don't have a solar sensor plugged in).
    Dixit
    Picture of Pool
    Sep 2014
    North DFW
    161
    I am using my solar for another jva, I can take a look at my dip switches and let you know how they are set after work.
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
    Jul 2012
    Duluth, GA (ATL)
    121
    That works, let me know if you have anything on the solar sensor pins, I think its 3 and 4 (next to the air temp and water temp sensors). Mine are open, and shows its OPENED on the iAqualink as well which is true.
    Dixit
    Picture of Pool
    Sep 2014
    North DFW
    161
    Ok, all of my dip switches are off.
    Pins 3 and 4 have nothing connected.
    I am using the solar JVA for my water feature.
    I'm sure you have the following image already, but I'll post it just in case. Its not the best quality.
    Jul 2012
    Duluth, GA (ATL)
    121
    Quote Originally Posted by PigIron View Post
    Dang it, then Im not sure why I cant use it. I have nothing connected to 3/4 pins. Originally all my dip switches were off too and that didn't help. somehow keeps thinking its USED and the Solar Sensor says OPENED. Wont let me re-assign it since it says USED.
    Dixit
    Picture of Pool
    Jul 2012
    Duluth, GA (ATL)
    121
    So asked Jandy support via email, they told me the following "This looks to be a glitch in the firmware. You can clear the memory and start over. This usually does the trick!"
    So I wrote down all my settings/schedule programs. Cleared the Memory. Before I did anything, went to Assign JVAs and noticed Solar JVA is still USED. So that didn't work!
    Dixit
    Picture of Pool
    Jul 2012
    Duluth, GA (ATL)
    121
    And as I knew, Jandy isn't going to help me any further.
    "At this point I have to suggest having a professional come out onsite to inspect the problem with the Solar JVA. I hope you understand that I want to help you solve this problem but I can’t do so through direct troubleshooting with you. Unfortunately we are limited to the types of troubleshooting we are able to conduct with pool owners. It’s not that we doubt your ability to work on our product, it is simply a safety issue for you, and a liability for the company, and we recommend you contact a pool professional in your area."
    Picture of Pool
