Results 1 to 7 of 7
Thread: Algae spots....advice
    Apr 2015
    coto de caza, ca
    3
    Hi I have never had problems with my pool before, but I ignored it and now it is not happy with me!
    I have a few spots, almost look like dirt on the pool. Wont brush off. Went in and tested pool, said no FC. PH was high. I added acid twice to lower ph and put in shook treatment one bag. It is better after a day but still have areas with the algae on them.
    They are recommending a yellow out, algaecide, clear aid product, phosphree product, and then a de filter change, when I did a change two weeks ago.
    Would love advice please...thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Algae spots....advice
    Hi, welcome to TFP!
    Do not buy any of that stuff. You do not need it and it will not help.
    Your first issue is not enough chlorine. What is your CYA level? Need to know CYA level to be able to suggest the correct amount of chlorine to add right now.
    Do you have a test kit? Is it one of these? Test Kit Comparison
    Read these
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    and get ready to do this after you get a good test kit
    SLAMing Your Pool
    Also, please update your signature and location as described here, http://www.troublefreepool.com/content/115-read-before-you-post
    Apr 2015
    coto de caza, ca
    3
    Thanks. My pool is beautiful blue water outside of several areas by my jacuzzi, under the light fixture, and in the crevices of the baja shelf plaster that looks like rock which have dirt looking brown/yellow colored algae. My CYA is 35 and i have 0 FC. I put shock in two days ago.
    I was going to add 2 gal. chlorine, and conditioner this morning. A guy who used to do my pool told me that would work. He said without conditioner the chlorine disappears. My PH is good, 7.6 and alkalinity good at 110.
    I have a salt pool and that is good as well.
    Apr 2015
    coto de caza, ca
    3
    Jun 2014
    Roseville, CA
    343
    From time to time, I get black mold on the tile joints.
    I get a chlorine tablet, rubber gloves, and rub the algae off as if using an eraser. That seems to really help.
    I use an algicide usually at the beginning of the season. I have solar panels so the pump runs a lot, so my chlorine is naturally high in the summer.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    DFW, TX
    24,468
    Is your conditioner cyanuric acid?
    The most important part of pool maintenance is never letting your chlorine level fall below the minimum level based on your CYA level. This is the only way to stop algae from getting a foothold. Chlorine CYA Chart
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    As long as you go this route, the problem will return. Until you start maintaining proper water balance, particarly Free Chlorine per your Cya, it will continue to be a problem.
    Essential Links:
