Results 1 to 8 of 8
Thread: Taylor Salt Test vs IC 40 SWG indicator
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Given the rain we've had lately, I am a loss as to why the SWG is still indicating all is fine with 3600 reading and no errors. I just did the Taylor test this a.m. and it showed 3000. I'm certainly more than inclined to take the Taylor test as authentic and add a sack of salt, but does anyone else with the IntelliChlor SWG system have this much of a variance in readings?
    Thanks
    B
    32 x 15 15500 gal. IG gunite, 6 ft. round attached spa, diamond brite 2 plaster, flagstone coping w/concrete spray deck, IntelliChlor IC-40 SWG, 2 hp Max-E-Pro pump, 450 sq.ft. System 3 cartridge filter, 400k Max-E-Therm NG heater, automation is IntelliTouch i7+3, Polaris 280 pressure side cleaner,
    TS 100, Borax
    Dec 2009
    Central Massachusetts
    2,690
    Re: Taylor Salt Test vs IC 40 SWG indicator
    IC-40 doesnt actually measure salt, it measures conductivity of the water. A 600 ppm variance is probably with in the error of either the test or the IC-40 reading. As long as the IC-40 is happy, thats what counts. It's fine, I wouldn't add any salt.
    Rain doesnt do that much to the salt concentration either unless you get a TON. 1 inch of water in a pool with your deminsions will add about 250 gallons of water, give or take. That amount of water wont do much to the overall salt concentration out of 15500 gallons of water.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    I agree, the tests are not all that precise. It is actually usual for them to come out the same. The Taylor test is +-400, and the IC40 is about the same. So they agree within the precision of the test.
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    I guess the Taylor test is a useful backup, but as long as the cell is clean and throwing reasonable readings, I'll just leave it alone and wait for the light.
    Thanks for the input!
    TS 100, Borax
    Jul 2014
    Peoria, IL
    389
    I use the Taylor test to make sure I am in the ballpark. Bottom line is my cell says to be at 3200 and that is where I try to keep it on the cells readout. The cells are programmed to run at maximum efficiency at a certain salt concentration. If your cell is happy and within range I say all good. And as mentioned above you would need a LOT of rain to move the needle on a 22,000 pool.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Yes. Leave it alone until it tells you it isnt happy.
    Quote Originally Posted by bware View Post
    Divin Dave,
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,537
    B.
    I'm the "Pool Boy" for three family pools. All three have IC40's and all three have the opposite of your readings. My IC40's consistently report about 400 ppm below the actual salt measured with the Taylor 1766. I try to add enough salt so that the SWG reports about 3400, and also trying not to go over 4K for the actual salt tests. Like everyone else, my only real concern is making sure the SWG does "think" the salt level is too low and shuts off.
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    The OP's numbers have about the variation in readings I get. As said above; as long as the cell is happy.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
