Thread: Technical guidance -Commercial pools
    Apr 2015
    Pembroke Pines, Florida
    3
    I am a hydraulic engineer for many years but only recently venturing into consulting/design of commercial swimming pools/spa. I am doing a large hotel pool (180,000 gal) with complete gutter system around pool (380 ft perimeter. Want to use collection tank. Estimate filtration rate to be at least 320 GPM. I am not familiar with main drain float valve in collection tank (need a pointer to suitable product - 2x6" lines?). When piping gutter from far end to pump room was planning 2 lines into collection tank increasing from 2" to 6" on each side with inlet pipes from gutter every 10 ft. Guidance would be appreciated. Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Technical guidance -Commercial pools
    You may find someone "In the Industry" here who may be able to help, but the vast majority of members here are home pool owners, not commercial operators.
    Support the site
    Apr 2015
    3
    Thanks for responding TFP Expert. Was looking at some of the comments on a previous thread and persons seemed pretty knowledgeable. Hoping to get some help.
    Mar 2011
    441
    You are asking for someone to give you free advice so you can in turn charge someone for these services. I'm really not interested in doing that, however I will say that 320gpm is inadequate to run a pool of that size. It's less than 1gpm per foot of weir. It's also less than a 6 hour turnover.
    It sounds to me like you might need to hire a consultant to help you with the entire scope of the design.
    20X40 30,000 gallon gunite pool
    Apr 2015
    3
    Quote Originally Posted by racket View Post
    Dear Racket,
    Seems like I miss understood this forum. I though it was a site where professionals shared ideas and helped each other. No disrespect meant. Thanks for advice anyway.
    Regards
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Actually, there are very few Pool Pros on the forum. The overwhelming majority are Pool owners. Some of us have different backgrounds in fields that are related or have things in common with pools/chemistry etc, but very few are actual Pool Professionals.
    Essential Links:
