Thread: Any concern with 4 wheel ThePoolCleaner in small'ish pool?
    Mar 2015
    Orlando, FL
    31
    I ordered a Hayward AquaNaut 200 (2 wheel ThePoolCleaner) from local pool store under the rebate + in-store credit promo deal. Hayward/Poolvergneugen is apparently having some issues getting enough manufactured to meet order demand and it's taken longer then promised to get me the 2 wheel model.
    I just received a call that they will be getting some 4 wheel models in this week and Hayward gave them permission to give me the 4 wheel model instead, which is about a $45 free "upgrade".
    With 14k gallons and only 6.5' deep end, is there any concern with the 4 wheel model? Hayward rep told my contact at the pool store there was no issue using the 4 wheel model. I could opt to continue to wait for a 2 wheel model, I'm in no rush.
    14k Gallon IG Gunite Pool | 13'x29' Rectangle with 13' x 4' Sun Shelf (shallow end)
    Magic Marcite Aqua Pearl Mini Pebble Interior in Bimini Blue
    Pentair IntelliFlo VS 011018 Pump, Pentair CCRP 200 Cartridge Filter, Pentair IC40 SWCG
    Pentair IntelliBrite 5G LED, Intermatic MultiWave Wireless Control System
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: Any concern with 4 wheel ThePoolCleaner in small'ish pool?
    I'm not sure if your specific question is directly answered here, but the following link includes a good series of Q&As from prospective customers. http://www.inyopools.com/Products/16300005059818.htm
    I wish I had more than one suction port that is actually my skimmer, as these things look very promising.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    38,284
    I think it should be fine. The 4 wheel just comes with more hoses (likely more than you need) and will travel a little further before it turns.
    Mar 2015
    Orlando, FL
    31
    I read about the extra hose, which I don't need, and that the 2 extra wheels give extra traction to drag more hose. I remember reading somewhere about minimum flow rates being slightly higher on the 4 wheel. I know flow rate won't be an issue for me with my pump. Guess it just means having to possibly using slightly higher pump speeds for it to do its thing.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It costs more to replace the tires (4 vs 2).
    Mark
    May 2012
    Cincinnati, OH
    189
    Yep that is a consideration. Google shows front tires available for $35 and rears at about $25.
    Check this thread for some initial comments on the life of tires. I'm sure you can find other discussions. http://www.troublefreepool.com/threa...-Replace-Tires
    This Q&A from Hayward also has some suggestions on deciding between the 2 vs 4 wheel versions. https://www.hayward-pool.com/pdf/tro...vergnuegen.pdf
