Thread: TA test during SLAM
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    TA test during SLAM
    I am using the TF100 test kit for my testing. I have a question about the TA color shift with an FC level of 31.
    The test instructions have a note that when there are high levels of chlorine, the initial color may shift to blue or yellow. When I test it goes from green to blue then to yellow but never goes to red. Is my correct TA level when it shifts to blue or when it shifts to yellow? I have several other test kits that all say my TA is 120, which is the same level when the TF100 test shifts to yellow. No matter how much reagent I add it never goes to red.
    My PH is 8.2+ but, I realize that may not be accurate because of the ongoing SLAM.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: TA test during SLAM
    It's working. High FC messes with the colors. green>pink becomes blue>yellow. Otherwise, no difference in how to run it. Why are you even bothering with that? During the SLAM, you concentrate on FC & CC. Everything else can be fixed in an afternoon once the water is clear and algae-free.
