Thread: Replacing Water in above ground pool
    Jul 2013
    Lawrenceburg, Indiana
    18
    Hello! I'm wanting to replace the water in my above ground pool. Is it safe to drain the pool and then refill or do I need to fill as I drain. I have a very high CYA and am trying to lower it. Thanks.
    26,000 gallon 33 foot round AG pool, cartridge filter, 175 SQ FT ECCO ELMNT FILTER 1.5 HP 2 SPEED, Southeastern IN
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Replacing Water in above ground pool
    I would not drain it completely. If it is just the CYA that you are worried about, I would drain about 1/3 and retest.
    These guys and gals will want a full set of readings to from a recommended test. I invested in the TF 100 and it is the best purchase I have made for my pool!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Leave a foot of water in the pool so the liner doesn't shift or wrinkle. The sidewall also won't collapse inwards if there's some water pushing against it.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    How high is your CYA level at? Depending how high it is will depend on how low to drain. Also, personally I'd train first then refill later after the amount you want drained is gone. But again, I don't think you need to drain it all, but that depends on your reading.
    Mike
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yes, 1/3-1/2 drain and refill is recommended.
    Casey's Avatar
    SW PA
    10,438
    Do you have test results to determine how much to drain?
