Results 1 to 19 of 19
Thread: AquaRite SWG won't keep generating
    Apr 2015
    Crystal Lake, Illinois
    6
    Question AquaRite SWG won't keep generating
    I have an AquaRite SWG that won't keep generating chlorine. After initial "on", the unit will generate with an amp reading @4.42, however shortly thereafter it stops generating and the amp reading drops to @0.02.
    The control is 8 seasons old, and the cell is new last season (2014). The system was working fine before winter closing last fall.
    Any thoughts?
    Re: AquaRite SWG won't keep generating
    Welcome to TFP!
    Unless the percentage setting is set to 100%, it is completely normal for the unit to cycle between on and off, being on for the given percentage of each 2 hour period.
    Are you seeing any error lights/codes?
    Apr 2015
    6
    No other codes or error lights. Unit is set at 100%, this also happens when I set to "Super Chlorinate".
    It will only generate for a few minutes (you can see the micro bubbles in the cell).
    I understand the unit works off a percentage of time per cycle; does the system stop generating when it reaches a certain chlorine level?
    Built new fall 2006; 23,000 gallon in ground vinyl liner pool, AquaRite SWG, Hayward paper media filter.
    Apr 2015
    6
    No other error codes present, all looks normal.
    Set to 100%, also "super chlorinate" setting reacts the same. After initial power on, generates like normal then 5 minutes or so it stops generating. Lights do not change.
    Will the system stop generating after reaching a certain chlorine level, or strictly a percentage of time per cycle.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Strictly percentage of time cycle.
    When set to 100% the unit should continue to generate the entire time the pump is on. The only exception I can think of is for cold water. Between 50 and 60 degrees it will only run a little, and below 50 degrees it won't run at all.
    Apr 2015
    6
    The water temp is hovering around 50-52 degrees. Usually the code "COLD" appears around 50 degrees and below. So maybe it is not generating, and not throwing the code?
    Can you post all of the diagnostic numbers?
    Support the site
    DFW, TX
    24,509
    I don't spend a lot of time trying to get my SWCG up and running until the water is consistently above 60. They are too finicky at lower temps. I just use bleach until then.
    When the water is very cold, but not cold enough to trigger a full shutdown, an AquaRite will often do exactly what you describe.
    Feb 2014
    Upstate, NY
    390
    I have the Aquarite as well. My water temp is at 52*. I have been using bleach just as Pooldv suggested. I just converted to SWG and haven't even added the salt yet.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Apr 2015
    6
    After initial power up and set to "Super Chlorinate":
    3200
    52
    27.1
    4.77
    100P
    -3200
    AL-1
    r1.4
    20 minutes later:
    3200
    52
    33.7
    0.04
    100P
    -0
    AL-1
    r1.4
    So for about 15-20 minutes it generates, sometimes not even that long. Cells look very clean, flow is good.
    Most likely it's just cold water. I would leave it off until the water temperature gets above 60 F.
    Support the site
    38,471
    Welcome to TFP!!!
    I will be the 5th person to tell you the water is too cold and just to use bleach
    DFW, TX
    24,509
    LOL! Where's Patrick and Tim?
    Apr 2015
    6
    Welcome to TFP!!!
    OK, I will wait for warmer weather and use bleach for now. Maybe I opened a little too early this year! Thanks for all the replies..
    Apr 2015
    Sainte-Julie Quebec Canada
    3
    I have the exactly the same problem. My cell is 3 years old. My water temp is at 60 deg...I.ll warm it up a bit more to see what happen. I phone Hayward and they told me my cell need replacement, but that is after I told them it was not a haward cell but a compupool!!!
    Feb 2014
    Upstate, NY
    390
    Welcome to TFP!!!
    This is exactly what I am doing as well. My water temp is 59* today.
    Apr 2015
    3
    YES!!! my water temp was at 65 at 8:00 last night and my wife started the Aqua-rite...I just check now 5 hrs later and it is still generating ...I need to make a note to my Aqua-rite door not to expect it to work below 65 degf. Now I remember that it did happened to me a few years ago...
    Bououo to the Haward rep that told me I needed a new cell after only 3 years of use.
