Results 1 to 8 of 8
Thread: PH is at 7.2 (Which step should I take) ?
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,258
    My PH is at 7.2. TA is at 80. CH is at 250. FC is at 8.5 and CC is at 0. CYA is at 30.
    Under pool math, it is recommend I add washing soda or soda ash. Pretty simple and straight forward.
    Question: Considering the pool has been opened early this year and the filter is running for approximately 4 hours a day, should I let the aeration of the pool increase the PH naturally?
    No one will be swimming, especially in very cold water. I have 6 returns that rotate, creating more aeration then normal (Believe so).
    Question: Is 7.2 PH safe for 30 days or so?
    Or should I add the chemicals as the aeration may not do the trick over the next few weeks.
    Question: How long does it take for PH to adjust and show during testing?
    Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PH is at 7.2 (Which step should I take) ?
    Did you add something to push it down to 7.2?
    Leave it alone, and it will increase. Check it in a few days and see if you get some rise. I don't know your pool, so I can't say exactly how fast it will come up. Test every few days and see what it does. This is something you need to learn about your pool's behavior.It won't stay at 7.2 for 30 days and it's no big deal, especially in a vinyl pool.
    Your returns shouldn't be breaking the surface much as a normal setup. If you want to do that to aerate to increase your pH faster, that's ok.
    Although its not a huge deal either, your FC is a little high. Did you increase to there for some reason?
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    PH of 7.2 is ok, it is at the bottom of the recommended level.
    Catanzaro's Avatar
    Jul 2014
    2,258
    I added some PH + yesterday in the pool after 30 minutes of turning the filter on. Maybe the PH did not register or the chemicals are too old. Also, the FC is high because I added a gallon of 12.5% for super chlorination. I figured that within a few days, the levels would be down to normal. Also wanted to determine how much in FC I am loosing daily, so I know how much to add. It appears that I lost 2 ppm in 1 day. This could be because of the initial clean up. Failed to mention that my pool cover had a few holes in it. I pumped too much water out of the pool over the winter and needed to fill the pool up at least one foot. With the introduction of fresh water into the pool, the PH could have dropped. This also could be why the CYA dropped from 50 to 30, etc.
    This will be my first full season with the TFP method. Last year I switched form the Frog system to the TFP method. Ironically I found someone who is using the Frog and sold him all my bac pacs, etc. Kind of worked out.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You should expect a 2 PPM loss under normal conditions. Nothing to worry about there. Just FYI, you can use Borax to raise pH. Or you can use washing Soda to raise pH and it's usually cheaper than buying pH Plus/up, which is the same product.
    Essential Links:
    Catanzaro's Avatar
    Jul 2014
    2,258
    The PH + was from when the pool was built. I only know to use the recommended chemicals from TFP. I know there is Borax, Washing Soda or Soda Ash.
    Heading to Wal-Mart in a few hours. Thank you.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Nothing wrong with it, I was just passing along the info is all.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I wouldn't bother adding anything. All those numbers are in the acceptable range. Micromanaging the chemistry will have you constantly tinkering with the water for no good reason. And if you have some overpriced pool chemicals left, use them when you need them. pH up = soda ash = washing soda. Same chemical, fancier packaging, fancier price. When it's gone, buy the cheaper grocery store equivalent the next time you need some.
