Thread: Re: Chlorine pucks / tabs without stabilizer / CYA
    Jul 2013
    Long Island, NY
    532
    Does anyone know if they ever made an chlorine pucks for a chlorinator? I don't want to use them due to some posters talking about how all of them increase your CYA.
    Would a good alternative (and probably cheaper) be to just pour in about some liquid bleach from walmart every night for the 15' above ground I am considering buying?
    I was trying to figure it out in pool math section but I think that section only shows you how to get to a 'target' number if you have a problem. Would anyone know how many oz daily or every 2 days to add of bleach to a 5500 gal above ground pool. Thanks all!
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    We think so, because it enables you to have tight reigns on your water balance. There are other things to control....Parameters like Cya (stabilizer). As for the dose, and other things you'll need to look at, there are tools like Pool Math and Information in Pool School.
    Start in Pool School with The ABCs and work your way through. We will be here to answer questions, so ask all you like.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here is a handy link, How to Chlorinate Your Pool
