Thread: Crystals seem to come off the wall by brushing
    Apr 2015
    Philly
    1
    I have been searching high and low for information on crystals in the pool. I have the same exact problem as this post! Our Polaris has probably taken lbs of this stuff out of the pool. I currently have a pile of it in the yard. The pool was replastered last spring and this is the first opening after the long freezing winter. The crystals seem to come off the wall by brushing although some are a bit more difficult to remove. Just had the water tested:
    FAC - 7 (just shocked heavily yesterday)
    TAC - 7
    CH - 420
    CYA - 25
    TA - 80
    PH - 8.5
    Acid - 6
    TDS - 1310
    Salt - 930 (chlorine pool for now)
    Phosphates - 700
    Re: Crystals seem to come off the wall by brushing
    Welcome to TFP!
    If they brush off you are lucky. Brush off and vacuum up as much of them as you can.
    Meanwhile, you need to get the PH down below 8.0.
    Longer term, I strongly recommend getting your own top quality test kit. Pool store test results have a history of being wrong way more frequently than you might expect. Without reliable test results it is impossible to know the best way to proceed.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi,
    Welcome to TFP.
    I am borrowing this from another member who posted it, (zea3)
    This should answer your question
    http://aquamagazine.com/content/post...-Crystals.aspx
    hope this helps,
    Quote Originally Posted by scottyroz View Post
    TAC - 7
    CH - 420
    CYA - 25
    TA - 80
    PH - 8.5
    Acid - 6
    TDS - 1310
    Phosphates - 700
    Divin Dave,
