Thread: Light Niche
    Apr 2015
    Brookline
    60
    Light Niche
    I need help finding a vinyl liner light niche for a new construction pool below 100 bucks. Will this work, it says sandwich gasket for vinyl but i am still unsure. Thanks http://www.amazon.com/dp/B0039PVP4S/...I2SFYUA7SMJDOW
    Southern New Hampshire, 18x36 single roman end pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Light Niche
    That link takes me to a light that says for concrete pool. I am not familiar with lights for vinyl liner pools. Hopefully someone who is will be along.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Light Niche
    That niche is also for a hot tub, so its very small.
    Quote Originally Posted by jhamblett View Post
    Divin Dave,
