Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: chlorine won't stay
    Apr 2015
    Star City, AR
    12
    chlorine won't stay
    We finally got our cover off yesterday and the water was clear, but algae settled to the bottom. As I turned on the auto-vac it stirred it up good and now the water is all green. Initial test (via strip) was
    FC-0
    Ph-6.8
    TA-240
    CYA-0
    Today:
    Ph-7.2 almost a full box of Borax added early this morning
    FC-0 maybe 1 1/2 gallons Bleach added-what I had on hand
    CYA-0
    TA-80
    Went to the store and purchased 10 gallons bleach, 2 boxes Borax, 2 bags Baking Soda, and 2 bottles of Stabilizer, and 5 pk of Super Shock (yeah, I know...), and a 6 in 1 test kit until my good one gets here
    Added 1 bottle stabilizer, 4 bags of shock and three hours later..
    Ph-7.2
    FC-.5
    CYA-40
    TA-80
    ...added 3 bottles of bleach
    WHY am I losing chlorine?? Is the algae just taking it? It needs to go away!! Once I get FC hopefully up to the 16 shock level should I retain it better? Do I keep adding chlorine every hour or so until it reaches shock or do I need to dump it all in?
    AGP replaced 2014 due to other pool blowing out; 33' x 52" round - 28K? gallons; SwimPRO sand filter SW256TPAKS; UtiliTech 1HP variable speed pump; 2014 PermaSalt 454007-chamber went out after 3 months-green pool
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: chlorine won't stay
    What is happening is the bleach is eating the algae. This will continue until all algae has been consumed by the bleach. Then your numbers on what you need to add will be less and less. uV rays from the sun will also affect your FC level.
    Also in the beginning of my SLAM I tested and added bleach every 2 hours as needed. I used pool math for the calculations on how much to add.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Apr 2015
    Star City, AR
    12
    Thanks! Should I be running the auto-vac overnight?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You want to keep it at FC Shock Level, Shock Level And Maintain and you will get results.
    I do not let mine run overnight in case something gets trapped. I only run mine during the day. Here is a link to my SLAM process. You really need to get a TF -100 test kit to be able to perform the SLAM properly.
    Page 9 is my pics from today
    http://www.troublefreepool.com/threads/90889-TF-100-readings-and-my-SLAM-process
    Lisa
    30,421
    No. Because you are killing so much algae, the auto-vac will clog up quickly and shut off. During this initial stage run the auto-vac only when you can check it every hour or perhaps less.
    STOP using the bags of shock.....your CYA looks like it is skyrocketing and you will have bigger problems.
    Apr 2015
    Star City, AR
    12
    I am getting the TF-100 on Friday, just wanting to get a jump on the green since it has been growing since last Summer when the Perma Salt chamber went out..lesson learned and staying away from that mess! Do you add bleach overnight as well to maintain?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by LimitlessWithLeVel View Post
    Great! I add bleach at 8/8:30 pm and then go to bed. I check it again around 6 am. I add some around noon/1pm also
    Lisa
    Apr 2015
    Star City, AR
    12
    Thank you so much!! It looks like your pool is coming along nicely!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome! Yes, it is coming along. Requires lots of patience and bleach. I recommend you upgrade your TF 100 with the XL add on as you will probably need it.
    Lisa
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Conducting a SLAM using test strips is a very bad idea. The results from them īs so poor that you really don't know what your levels of anything are.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Hi, welcome to TFP!
    Have you read, SLAMing Your Pool?
    Casey's Avatar
    SW PA
    10,444
    To go along with what Tim has said regarding the strips. You first reported a TA of 240 n then another TA of 80. That's night n day difference!
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I was just reading and wanted to point out that limitless mentioned purchasing a 6 in 1 kit to use while waiting for the TF-100 (coming Friday?) So that is probably an OTO chlorine test....the strips were just the first report.
    But I'll add... you can't really do much but sit in a holding pattern until you get the right chlorine test (the one that comes with the TF-100) If your CYA is truely 40 now (possibly higher since you've added the stabilizer *and* the shock which probably also had CYA in it)...you're going to need a higher FC than your test can measure. Be careful of adding anything else before your kit comes. A few more days of green isn't going to make that much of a difference.
    I know you want to get started but if you can't test your chlorine at the level it needs to be you could very well be wasting it since the algae will be able to grow back faster than you can kill it. You need the precision of the FAS/DPD chlorine test to achieve and maintain that level.
    Here's hoping for a quick test kit delivery!!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Apr 2015
    Star City, AR
    12
    The first TA was with the strip..all other results are from the test kit. Today we have turquoise cloudy water with lots of floaties. I have vac going now. This mornings results:
    Ph 7.2
    FC 5+
    TA 90
    CYA 30
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Ph 7.2
    FC 5+
    TA 90
    CYA 30
    What test kit do you have? If you already posted it, I apologize for asking.
    Lisa
    Apr 2015
    Star City, AR
    12
    It's only hth 6-in-1..also, I did the hardness test but it didn't change colors
    May 2014
    Franklin, NC
    9,184
    With a lined pool CH is not an issue unless it gets above 350. Let's hope you get the TF100 soon as right now you are kind of shooting in the dark. Your shock level is 12 and the 5+ doesn't tell you that you are there. If you are close to 12 the "yellow" color on your 6-way should be as dark as a school bus, almost turning orange. Anything less than 12 you are killing algae, but they are growing faster than you can kill them. That is the basis of the shock level in that once you get to shock you are killing them faster than they can reproduce.
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I hope your TF 100 arrives quickly! Once you have that you will find things will go much easier. Did you order a speed stir too? I highly recommend one.
    Lisa
    Apr 2015
    Star City, AR
    12
    Ok, so went to local pool store..don't worry, didn't buy anything, lol. Got the water computerized tested..
    CYA-13
    CC-10
    FC-8.4
    Ph-7.4
    TA-104
    Adj. TA-100
    CH-67
    They recommended BioGuard's Power Flock, but it's raining so I had an excuse not to buy. She said not to add stabilizer until clear because of all the vacuuming and backwashing, but with CYA only being 13, don't I need it up first to help retain Chlorine?
  20. Back To Top    #20
    Aug 2014
    Shallotte, NC
    693
    Don't worry about the CYA, yet..... just hold your FC at 10.0 or better. Until you get your test kit and do your own test, you are just guessing.
