Results 1 to 10 of 10
Thread: Quikrete pool sand comments?
    Apr 2015
    Leesburg, GA
    49
    I just bought a 50lb bag of Quikrete pool sand from Home Depot for $5.48. I am using it in an Intex sand filter. I assume it will work ok. Has anyone here had good/bad experience with this product?
    20' Intex; 52" deep; 8,638 gal; above ground. Intex 1,600 GPH sand filter.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Quikrete pool sand comments?
    I bought 350 lbs of it from Lowes for about the same price. I had no problems with it.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Pool sand is what you want. Officially, #20 pool sand.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    make sure it says #20 on the bag. (thats the average size of grains). To small and it go got through the laterals and into the pool, too big and it wont filter as well as it should.
    you beat me to it! again!
    Quote Originally Posted by pooldv View Post
    Divin Dave,
    DFW, TX
    24,497
    Only by 2 min!
    Apr 2015
    Leesburg, GA
    49
    The Quikrete sand seems to be filtering ok except I am experiencing the following:
    I have used this sand in an Intex filter previously with no problem. I got a new Intex filter and installed this sand (one 50 lb bag). I backwashed/rinsed as directed. It rinsed well and seemed to be working as expected. After about a week I noticed I had very little water volume. I backwashed and noticed I was losing some sand, maybe about a quart-sized amount or so. The sand I lost was very fine. I rinsed to level the sand and resumed operation, thinking this would be a one-time occurrence. A week or so later, same thing. Like clockwork, after another week, same thing. Each time I backwash I notice the sight glass fills up with very fine sand particles and the water that is expelled is the tan color of the sand. The glass clears up during the rinse.
    It's not blowing sand into the pool but I continue to lose a more-than-expected amount of sand each time I backwash. This did not happen with the same brand of sand and filter previously.
    I can only assume there is an excessive amount of very fine sand in the bag I purchased. I plan to purchase a different brand of sand to add to the top in order to bring the sand level back up to spec.
    Hopefully my filter has expelled most of the sand that is too fine for the filter and the addition of a layer of coarser sand will solve the problem without having to change out all of the sand.
    Does anybody have any recommendations/ideas as to what may be happening here and maybe a better way of dealing with it.
    Maybe it will clear up after another backwash or two and operation will normalize...
    Normally you would only lose sand like that if either you put too much sand in to the filter to begin with, or if the pump is much larger than what the filter is designed for.
    Jul 2014
    Oakbank, Canada
    389
    Everything is fine, you will always see a little bit if sand in the sight glass the way you mentioned. It's even mentioned in the instructions for the sand filter (mine did anyways) .
    You have a pressure gauge on it? What was the pressure at when you noticed the water flow was down?
    Quote Originally Posted by billy0952 View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Apr 2015
    Leesburg, GA
    49
    My pressure gauge, after backwash, normally runs just slightly in the green area. It creeps up a short distance into the yellow area after roughly five days and the water flow cuts down substantially after a week with the gauge only a short distance into the yellow area.
    Unfortunately, my gauge doesn't read PSI. It just gives a "relative" indication which gives a ballpark guestimate which I presume is sufficient to let me know when to backwash.
    Quote Originally Posted by DarrelB View Post
    Apr 2015
    Leesburg, GA
    49
    I've only backwashed three or four times thus far and have not opened the tank to check the sand level. I expect I will continue as-is for a few more backwashes to see if the volume of fine sand expelled diminishes to a smaller amount at which point I will assume all is well.
    If it continues to expel a tea cup amount of sand at each backwash I presume I will need to "top off" the sand level in the tank occasionally.
