Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Cloudiness and Yellow dust comes back within a few days of stopping Slam
    Apr 2015
    Round Rock, TX
    25
    Unhappy Cloudiness and Yellow dust comes back within a few days of stopping Slam
    I did two weeks of slamming my pool, until the water was the clearest I've seen for a couple of years. No drop overnight of Chlorine, and .5 CC level.
    After a couple days of starting to lower the chlorine, I've gotten back to a cloudy pool. I'm wondering what I should do now. I just ran all the tests, with the following results.
    FC - 3.0
    CC - 0.5
    CYA - 45-50
    PH - 7.8(up from 7.5 yesterday)
    TA - 90
    CH - 550
    I'm going to bring the PH down right now, and then bring up the Chlorine to 6 after 30 mins.
    CH seems a bit high, but consistent with the water being hard in this area, I believe.
    12,350 gallon IG plaster pool
    Hayward cartridge Swimclear 4025 filter
    Hayward Super II 2.5 Hp pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Cloudiness and Yellow dust comes back within a few days of stopping Slam
    Well, your FC is too low for your CYA. You may have had a little algae sneak back in there.
    Or, pollen maybe.
    Bring the FC up around 10 and do another OCLT tonight to see if anything is growing.
    Support the site
    38,251
    For a CYA of 50ppm, the minimum you should EVER let the FC get is 4ppm ... so you should be targeting about 7ppm every day.
    Apr 2015
    Round Rock, TX
    25
    The FC only got down to 3.0 over the last night/morning, I had been keeping it between 5 and 7 once it moved down from SLAM levels. I didn't get a chance to add chlorine this morning because of a rainstorm. I had upped it to 8 last night, so I was not expecting it to go down that low by this afternoon.
    Apr 2015
    Round Rock, TX
    25
    Looked back over my notes, and I raised the chlorine from 5 to 8 yesterday morning, not night. I expected it to be back around 5 today.
    There is for sure a lot of pollen in there, with two thunderstorms in the last three days. I assumed if I kept FC from 5 to 8 it would keep everything at bay. I definitely did not expect the level to get down to 3 in one day.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, 6-8 will keep it at bay, but dropping to 3 it will start growing fast. Have to keep it above 4 or 5 at all times. Good job having some notes! I like it.
    Apr 2015
    Round Rock, TX
    25
    The pool passed the overnight OCLT test, and CC is around 0.5.
    I guess the cloudiness is just from lots of pollen(rained again overnight). I've got the FC around 13.0, and will try to keep it above 10 for a few days.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Won't hurt anything, but doesn't sound like you need too.
    Essential Links:
    Apr 2015
    Round Rock, TX
    25
    I've kept the chlorine above 10 for the past two days, and things keep getting worse. I can barely see the bottom, and every time I sweep the pool there is a layer of yellow powder that is stirred up. This layer keeps getting larger every day.
    Anybody have any suggestions?
    38,251
    How much are you running the pump?
    How big is your filter? (add to your signature)
    How often are you needing to clean the filter?
    Apr 2015
    Round Rock, TX
    25
    I'm running the pump 24/7 right now. I added the filter model to my signature. I'm not sure what the sizing of a filter is. Is it the flow rate? If so, it says 150 gallons/minute.
    I cleaned the filter on Saturday, and it was not dirty at all, other than being yellow. There wasn't much, if any, particles in the filter fins.
    DFW, TX
    24,450
    Starting to sound more and more like algae. I think you might need to read up on SLAMing Your Pool
    Apr 2015
    Round Rock, TX
    25
    From this thread:
    http://www.troublefreepool.com/threa...w-in-the-towel
    I think maybe it is yellow mustard algae. Maybe I should bring up to mustard shock level for a couple days?
    I did a regular SLAM, and the water was clear, but as soon as I started to move the chlorine down, the water started to get cloudy.
    DFW, TX
    24,450
    That sounds just like Mustard Algae. Here is an article on that, http://www.troublefreepool.com/conte...-mustard-algae
    38,251
    Mustard algae does not typically make the water cloudy. It just grows in the shade: http://www.troublefreepool.com/conte...-mustard-algae
    You have a big filter, so I am surprised you are not filtering anything out. I too am thinking maybe you should SLAM again.
    DFW, TX
    24,450
    Haven't read a lot on mustard algae before. Looks like some bad stuff! Good luck.
    Apr 2015
    Round Rock, TX
    25
    hmm, the more I look up about mustard algae, the less it seems that's what it is. I have a shallow ledge, and the yellow color accumulates around where I have a small fountain. That whole area is in the sun most of the day, so I would think that this wouldn't be where mustard algae would be the thickest..
    I'm going to try a skimmer sock to see how much pollen it collects daily.
    DFW, TX
    24,450
    Well, it would be good news if it isn't! Is there yellow stuff on the pool deck? Furniture? Cars? When we were in prime pollen season a couple of weeks ago I got our old truck out from the barnyard to haul some stuff and it was green and fuzzy! Also, hosing off the pool deck and it was greenish.
    Apr 2015
    Round Rock, TX
    25
    yes, it is prime pollen season here. I'm hoping that the last few days of rain have finally cleared the air.
    I just wish there were a quick way to get the water back clear, if it is pollen.
  20. Back To Top    #20
    DFW, TX
    24,450
    skimmer socks and 24x7 running the pump (on low if you have VS or 2 speed) to filter it our are really the best options for that. Careful with the skimmer socks, I've had them clog completely and shut off all water flow through the skimmers before.
