Thread: Maytronics M5/M500 Power Supply Part Number
    Feb 2015
    CA
    14
    Hi,
    I am trying to investigate why the delay function of the Maytronics Pro Remote (99954226-ASSY) is not working on my Dolphin Triton Plus. I had confirmed with Maytronics Support before that it should work with my power supply (part no 9995678) but after receiving the remote it definitely does not work.
    Could somebody with a M5/M500 let me know what the power supply part number is? It is printed on the bottom of the power supply and starts with 999.
    29000 gal outdoor in-ground 38' x 20' kidney plaster pool; Pentair 011017; FlowVis
    Hayward DE3620; Heliomatic solar heater 6panel; Maytronics Dolphin Triton Plus
    Feb 2015
    CA
    14
    Re: Maytronics M5/M500 Power Supply Part Number
    I actually just found an ebay listing that shows which power supply fits which robot. However, this does not explain why the delay start does not work on my Triton Plus.
    9995670 - Power Supply fits the following pool cleaners:
    Advantage - 9999301
    3001 - 9999321
    SCP - 9999301-SCP
    Commander - 9999301-COM
    Sprite - 9999301-SPR
    Deluxe + Caddy - 9999311-DLX
    3001 - 9999321-BL
    Nautilus - 99996323
    Saturn - 99996306
    Saturn - 99996319-SAT
    DX5 - 9999311-DX5
    Heavy Duty - 9999389-HD
    Deluxe 4 - 99996351
    9995671 - Power Supply fits the following pool cleaners:
    PRO X2 - 9999393X
    PRO X2 - 9999393X-BL
    PRO X2 - 9999399X-BL
    Wave 90 - 99991083-W90
    Wave 100 - 9999396X
    Supreme M5 - 99991083-US
    DX6 - 99996363-DX6
    Advantage Plus with Caddy - 9999313RC
    Advantage Plus Pro - 9999336-ADV
    3001 - 9999326-BL
    Enduro - 9999343X-END
    9995672 - Power Supply fits the following pool cleaners:
    Interactive 9999301-INT
    Explorer - 9999301-EXP
    Supreme M3 - 99996333-US
    DX3 - 99996333-DX3
    Endeavor - 99996316
    Atlantis Basic - 99996303
    Quest - 99996329
    9995678 - Power Supply fits the following pool cleaners:
    Heavy Duty - 9999381
    Supreme M4 - 99991013-US
    Supreme M5 - 99991086-US
    DX4 - 99996343-DX4
    DX6 - 99996369-DX6
    Apollo - 99996343
    Apollo Plus - 99996053-US
    Triton - 99996356
    Edge - 99996359
    Discovery - 99996349
    Wave 50 - 9999386
    Wave 75 - 99996366
    Wave 75 - 99996369-W75
    Premier - 99996339
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Just a quick thought in troubleshooting this. Instead of the power pack having the timer, is it possible that the M5 remote has a built in timer and sends the delayed start function to the power pack after the time lapse, and therefore it must be in close proximity to the unit when the time lapses. If so, do you have the remote close enough to operate it at that time?
    An M5 owner that has used the remote for this for this feature can likely confirm whether this is the case.
    I am curious about the outcome of this in general, as I am considering buying an M5(500).
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Feb 2015
    CA
    14
    I did leave the remote close to the battery pack. but the fact that the robot immediately starts tells me it is not the remote sending the signal. Also, all remotes - the original and the pro model - switch off after a few minutes of inactivity. One difference I noticed between the original and the pro model is that the pro model does not give an audible confirmation when you hit the OK button.
    If there is a M5(00) owner out there could you please confirm if you get an audio confirmation when you press the OK button? Maybe the remote is broken or at least the part that sends the programming. The manual mode works fine after all.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Mine does give the audible with the OK button. I'm certain of it. Mine too goes off rather quickly when not used.
    Essential Links:
