Thread: Can anyone tell me about adding DE to sand filter?
    Thanks in advance. This forum is awesome and has been a great help to me.
    I read that you can add diatamateous (sp?) earth through the skimmer to bring filtering to about 4 microns. I used zeosand in my Hayward Pro sand filter and running a 1 1/2hp pump. Someone told me it would just blow back into the pool.
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    30,426
    Re: Can anyone tell me about adding DE to sand filter?
    Not sure what your question is. Do you have zeo in your filter now?
    38,371
    How to Add DE to a Sand Filter ... although not sure it is a good idea with Zeosand (which I am not sure gets very good reviews here, seems like regular sand is better).
    Well the filter calls for 300lbs of #20 pool sand or 150lbs of zeosand. I opted for zeosand and may question is about adding a layer of DE for extra filtration, and if it is a good idea is it ok to add the DE through the skimmer as I had read somewhere else?
    Orlando, FL
    690
    I used to add it through the skimmer with no issues but I had filter sand. You don't add that much, it did not blow back, and after you backwash the filter you will need to add it again. It's cheap enough that you could buy it and try. I got the cellulous at Home Depot, which is a DE substitute.
    I don't add it anymore because once my chemical balance was aligned, I stopped having to backwash my filter so much, which allows it to do the job. My pool is crystal clear. I also learned that "a little cloudy" has everything to do with algae and very little to do with my filter not filtering properly.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    30,426
    I get it, now. I would not add DE to zeo. Why do you want to? Is your water not Crystal clear?
