Results 1 to 7 of 7
Thread: 1st time pool owner
    Apr 2015
    White pine/tn
    2
    1st time pool owner
    I am about to purchase a AGP. I was considering perma salt, until I found this forum. What would you recommend for a new fill/start up?
    30,426
    Re: 1st time pool owner
    Welcome to the forum.
    I assume you mean for sanitation and keeping your pool clear?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Essential Links:
    38,364
    Welcome to TFP!!!
    How big of a pool are we talking about? The short answer is that you want chlorine to keep the pool safe.
    Apr 2015
    White pine/tn
    2
    Correct.
    25k, 33' AG. I guess what I am asking is, how does one start with the bbb method? Order a test kit, fill pool, test water(which parameters), then???
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Welcome! If you do use the TFP way you will have a clean and clear pool forever!
    -order test kit
    -fill pool
    -find good source of bleach/chlorine
    -buy CYA (aka pool balance or stabilizer) you can buy it at walmart
    -test water
    -post test results here
    -follow directions given to balance pool
    There you have it!
    Please go to the link below to read about what you need to now about keeping your pool clear. It is a LOT to take in so you will need to read it a few times. It will get easier over time.
    http://www.troublefreepool.com/conte...ater-chemistry
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP! Please update your signature as shown here.
    Also, more here, TFPC for Beginners
