Thread: Just Purchased Coleman 18' x 9' x 48" Power Steel Rectangular Frame - WORRIED NOW
    CGraham's Avatar
    Apr 2015
    Terrell, Tx
    6
    DONE
    May 2015
    Ankeny/IA
    1
    Re: Just Purchased Coleman 18' x 9' x 48" Power Steel Rectangular Frame - WORRIED NOW
    Quote Originally Posted by CGraham View Post
    DONE
    Why are you worried? I just purchased the same pool and it is filling as we speak, do you have a problem with yours?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you level the spot you are placing your pool to within 1" and place pavers under each leg, you should have no problems with your pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP! How are you planning to chlorinate your pool?
    Here are some intro Pool School articles to read.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
