Thread: Replace Hayward Astrolite w/ Intellibrite 5g in Sp-607 niche?
    Jan 2013
    Cleveland, OH
    70
    Current Light: Hayward Astrolite SP0583L50 in a Hayward SP607 Niche.
    Want to replace w/ an Intellibrite 5g model but it appears that the Intellibrite 5g has an outside ring diameter of 10.12" while current Hayward Light is 10.875" ring diameter. Can't really find specs on niche faceplate overlap so not sure Intellibrite will fit. Have seen anecdotal evidence on the Web that "...it will fit." but you know how accurate free info can be.
    Thoughts? Really wanna go Intellibrite over Colorlogic as have heard colorlogic not as bright/widespread due to Intellibrite lens design advantage.
    So, anyone know if Intellibright 5g (601002) will fit nicely in SP607 niche without hacking it, light wedges, etc.?
    Thanks
    20K gal, vinyl, 1 HP Challenger 2-spd pump, 300 lb sand filter, Raypak 266K BTU, 45M stenner pumpin' bleach
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Re: Replace Hayward Astrolite w/ Intellibrite 5g in Sp-607 niche?
    I will get you an answer. Remember, many times mixing light and niche will negate the UL approval. Check with Pentair to see if they are approved in our niche.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jan 2013
    Cleveland, OH
    70
    Yeah, looks like a no-go. Pentair says:
    "Unfortunately, we would not be able to recommend installing our light into a Hayward niche nor can we recommend an adapter to fit an Intellibrite as well, only option we would have in this case is to remove the existing niche and install the proper Pentair niche."
    Oh well, looks like I stick with another Astrolite...heck, lasted 18 years, not even a bulb replacement. Believe it to be leaking, not from gasket but from cord into housing area.
    Oct 2014
    Elizabeth
    426
    Our team is trying to fit their light in our niche. If there are any changes we will let you know.
    Hayward Pool Tech
    Mar 2011
    441
    In my practical experience every light that is a large pool light will fit in any manufacturers niche.
    The exception to this would be the Sta-rite light and some Hydrel lights.
    I have in the past used amerlites in hayward niches and the intellibrite has the same mounting design as the amerlite. So it should fit.
    20X40 30,000 gallon gunite pool
