Results 1 to 11 of 11
Thread: Nicaragua situation
    Dec 2014
    Rivas, Nicaragua
    83
    Nicaragua situation
    The availability of some products is weird here sometimes. Or I should say the products some businesses choose to inventory is weird here.
    My pool completed about March 20th. This site has been fantastic for the design and build.
    Our water is absolutely dead clear perfect thanks to this method. (Non pool store method).
    One challnge is the availability of liquid bleach/chlorine here. All of it that I can find in any kind of store is 3%. This becomes very cumbersome and costly.
    We have a pool store and they sell aqua-chlor which i bought a large tote of and have been using that but closely watching the CYA level.
    I have twice run it up to around 90 and replaced water to lower it to 40.
    I built a permanent plumbed-in pump to waste line which send the water to the street so changing water is very easy and a non issue. Neighbors appreciate it actually because this is dry season and it keeps dust down. Water is not expensive.
    Last night's test (with strip, I test weekly with the kit for all parameters to verify accuracy of strips, PH amd CYA tested with the kit every night -chlorine levels seem to be accurate with the strips):
    TH 250
    TC 5
    FC 5
    PH 7.4
    TA 80
    CYA 60
    My question is this: Is this a viable way to operate the water management of my pool? What alternatives to dumping water to control the CYA are there? Ideas?
    Our water is very inexpensive here.
    (The privacy wall and a few other small things are still under construction)
    Warren in Rivas, Nicaragua
    10,000 Gallon all mosaic tile pool- Whisperflo 2 speed 1.5hp - Pentair CC plus 420sf - Polaris 280 - 2 Intellibrite LED - 2 Intellibrite LED bubbler - 4 Jandy deck jet - 1 sheer descent - no automation - autofill - K-2006 test kit - pool deck 540sf - porch attached to pool deck -740 sf - My build thread
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Nicaragua situation
    Not really too many options with that situation. However, if you could acquire a test kit that showed your Calcium level, we might be able to suggest Cal-Hypo as an alternative should they sell that down there.
    Essential Links:
    Replacing water can be a viable solution, you just need to keep in mind that replacing water will affect all of your levels. At a minimum you will likely need to add calcium regularly, and it is possible that some of your other levels will also require frequent attention.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Is the Aqua-Chlor a liquid or solid? All Google references I found in Central America relate to liquid products that are 6-7% chlorine which would have no CYA
    Support the site
    Dec 2014
    Rivas, Nicaragua
    83
    Granular. It is high concentration. I believe 90% and using that number in the pool calculator seems to be correct. The label says stabilized and my CYA rises weekly. The data sheet is fuzzy on CYA.
    Datasheet here: http://aquachlorpool.com/download/265/
    Product here: http://aquachlorpool.com/quimicos/sa...hlor-duraclor/
    That is what we call trichlor, raises the FC and CYA levels, and lowers PH.
    Granular trichlor isn't normally the best thing to use because it dissolves fairly slowly. You want to make sure that undissolved pile of powder don't sit on the pool surface.
    Dec 2014
    Rivas, Nicaragua
    83
    That is the only product readily available.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's too bad. You'll have to keep refilling, or find another source like Cal-Hypo. As Tim suggested though, perhaps you can find some of the 6-7% Chlorine Bleach.
    Essential Links:
    May 2014
    Franklin, NC
    9,184
    T he logo on that container is the same one I found on a website indicating they produced 6-7% liquid. Do a little more Internet searching as I was "limited" to my English only searching.
    Support the site
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    If you're having a hard time sourcing chlorine how about a salt water chlorine generator? If you can get one plus some salt and install it you won't have to go out and find chlorine again.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Mar 2015
    Sydney, australia
    21
    If you get a SWG you could also significantly over-size it for your pool (and run it at only 10-20%). That way if you need to increase the chlorine level suddenly, you can do so.
    32,000 litre in-ground painted concrete pool
    Zodiac Tri-Mid +ph SWG
    Solar pool heating
    Taylor K-2006 test kit
    In Sydney, Australia
