Results 1 to 7 of 7
Thread: ? about floating solar powered salt water chlorine generator
    I was wondering if anyone here knows about these and how well they work and how long the cells last?
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: ? about floating solar powered salt water chlorine generator
    Don't think they'll create enough chlorine to be effective. Do they tell the out put? How many watts are the solar cells?
    A couple of different brands of floating solar SWGs have gotten fairly negative reviews in the past. They tend to be way underpowered and are often lacking the self cleaning feature as well.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    About ten minutes ago I was looking at Home Depot to find a tree to replace one downed in a storm Saturday and came across a solar powered floating pool filter. It claims a life of thirty years and states you can just turn off your existing pool equipment and help save the planet. And it can be yours for only $799.00. Yeah, right. Somehow I don't think this will get the job done just like the solar powered SWCG.
    http://t.homedepot.com/p/Natural-Cur...&showPLP=false
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Quote Originally Posted by ComputerGuyInNOLA View Post
    It is 3'x3'x1' and weighs 38 lbs dry. That is a significant obstruction when swimming and not so easy to get in and out of the pool.
    Quote Originally Posted by bobodaclown View Post
    It says it's rated for 15k gallons. I just switched my filter system from cartridge to sand and had to replace a frozen pump. I was interested in a swcg but couldn't afford it after replacing the filter system. I was thinking maybe this floater would help with the chlorine. Maybe it's too good to be true. Have only found 2 reviews and while it says it will last for 8 years...I don't think they've been out long enough to verify.
    Apr 2011
    Murrieta, CA
    2,360
    I'd pass. For that price you could get a Compupool or other brand full sized unit.
