Thread: Finally became a supporter!
    brauh01's Avatar
    Jul 2012
    Yardley, PA
    66
    Well, I've finally done it. I admit I should have done it sooner. Thanks for all the free, generous, and helpful advice!
    Brauh01
    23,500 gallon IG plaster with pebbles, Pentair FLT FNS 60 DE (160 GPM flow rate), Pentair Model 320 in-line Chlorinator, Jandy Plus HP 1.5 HP pump replaced with AO Centurian 1.5 switchless motor; Aquacal Heatwave heat pump. Method: since 2012 transitioned from "pool-stored" to TFP! Get your test kits here: TFTestkits.net correct link for pool calculator: http://www.troublefreepool.com/calc.html
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Re: Finally became a supporter!
    I love first posts like these! Welcome to the forum!!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Thanks! Better late than never. Continue to enjoy the generous, helpful and now slightly less than free help.
