Results 1 to 10 of 10
Thread: Jandy valve connected directly to pump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Is it ok to run my pipe like this? It made the most sense to me but I dont do it all the time... The other side of the jandy valve will be "to waste" It lines up perfectly like this.. it is not glued or connected permenantly yet, just trying to figure the best way...
    The pool will be behind where I took the picture (behind me)
    Is there a better way to connect it up?
    should I move the filter further away?
    will a 90 degree elbow out of the filter be ok?
    Thanks for the help
    Jul 2014
    Peoria, IL
    389
    Re: Jandy valve connected directly to pump
    I think it will be fine like it is. Just make sure to not flood the underground tornado shelter with the waste water.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, a 90 out of the filter is fine. Run some straight pipe before turning the 90 so you have some room to work. Not sure if the jandy valve is ok or not. Have to see what other people think. I'd be inclined to 90 out of the pump and put the jandy in the straight piece.
    Jul 2007
    Suwanee, GA
    528
    I'd probably put a 90 on top of the pump and put the valve on the straight pipe. It'll probably lower it a bit as well, making that pipe closer to parallel with the ground. You may have to break the tab on the handle to allow the valve to close off the third port.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Jul 2013
    Fletcher, OK
    3,353
    i should have mentioned that crabboy,
    the union is not tight against the pump, it has about .5 inches to snug up, that will drop the connection down and go straight into the filter.. I am just trying to line everything up before I glue anything
    Jul 2013
    Fletcher, OK
    3,353
    Ok, I looked at changing the layout, by turning the filter 90 degrees it would take 4 90 degree turns to get back to the filter... I know 3 90 degree turns don't add much, but I really like only 1 90 in the jandy valve and directly to the filter.. I also looked at adding just a 90 and then straight pipe to the jandy, everyone has said to only not use the tee off the jandy if there is no iother way to do it... unless it is just plain wrong to do it this way I think that is the direction I am going...
    You should be fine. The only risk is if the pump runs dry and overheats, you will probably lose the valve as well as the pump, but that is really rare and losing the valve as well is hardly the end of the world.
    Jul 2013
    Fletcher, OK
    3,353
    Thanks Jason, I am working on an auto filler but want to make sure it will work before I put it online
    Jul 2013
    Fletcher, OK
    3,353
    It worked out great, A little at a time..
    DFW, TX
    24,497
    Nice work!
