Thread: Hayward 244T sand filter PSI gauge won't stay on
    Apr 2014
    Mississippi
    3
    I just received a new PSI glycerin filled gauge from TFTestkits. I wrapped the threads with teflon tape and screwed it in. I noticed that it didn't seem to tighten well after several turned unlike the old one I took out. I turned the pump on and seconds later, the gauge blew out. I tried wrapping more tape on it with the same effect. So I put the old one back on. Any recommendations on how I can get a tighter fit?
    34,000 gallon grecian-shaped vinyl pool, Hayward S244T sand filter, 1 HP pump, Polaris 280, TF-100 Test Kit
    30,424
    Re: Hayward 244T sand filter PSI gauge won't stay on
    Most filters are 1/4" npt for that fitting. What kind of filter do you have. I am a minimalist concerning teflon tape.....3-4 wraps should be plenty.
    No other reported problems with the threads of which I am aware.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Wow, not sure on this situation. Make sure the threads are the same. Could be the problem. Be careful not to damage the threads on the valve.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Mar 2011
    441
    The hayward multiport valves tend to be extremely fragile. Finger snug is all I ever tighten a gauge into them. It would be really hard to put a pressure gauge that is the wrong size in a valve, so I am betting that the valve is broken.
    20X40 30,000 gallon gunite pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sounds possible the previous install was cross threaded...
    Essential Links:
