Thread: IC20 @ 1% 8 hours a day: way too much chlorine
    Apr 2015
    Portland, OR
    2
    I have a 3500 gallon pool/spa (small) and an IC20 SWG. I run it at 1% only on spa mode which runs 8 hours a day and in a week the FC will go from near 0 to off the chart. Turning it off completely brings it back down over time. Is there something wrong with my IC20 or is there some way I can use a smaller tablet or something?
    Nate
    Re: IC20 @ 1% 8 hours a day: way too much chlorine
    Welcome to TFP!
    We don't recommend using a SWG larger than 3 times the size of your pool. Your is roughly six times larger, which is going to cause problems such as the one you describe.
    I would start by cutting your run time down to two or three hours a day. Eight hours a day is way more than you are likely to need and is also contributing to your problem.
    Longer term, you might also want to consider lowering the CYA level a little. That will help keep the FC level from getting too high.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I cant remember exactly, but maybe someone will.. do you have the IC20 connected to any pentair automation? (suntouch, solartouch, easytouch) I remember reading some where that without pentair automation you can only adjust at 20% increments.. so even though you think its 1% its actually 20%...
    Can someone confirm or deny this, I seem to have a case of CRS and google is not finding the info...
    cowboycasey, you are correct. But it doesn't really make any difference to natethelen in this situation. The only alternative that isn't very expensive is to lower the run time.
    Apr 2015
    Portland, OR
    2
    Yes, I have an intellitouch system. I have dropped it down to running the spa for only 4 hours a day and may drop it even more if necessary. So the 20 in IC 20 is 1000's of gallons? Is there nothing smaller?
    There are slightly smaller units, such as the Pentair IC15, but nothing significantly smaller.
