Thread: outdoor kitchen build in Phoenix, AZ
    I'm in the process of buying a house that has a built in island... However the owners are taking it. I think it won't move well but whatever..
    The current island runs on a propane tank so location of my new island will be up for grabs. I've had a couple built ins but never built one myself. It will be a slow process as I work away from from home and have a few days a month to actually work on it starting next month.
    Here is what I am working on doing and a few pics of the yard.
    I of course want the grill, probably a 3-4 burner. A fridge, a drawer set up, a cabinet, a fire area on the counter, a sink and maybe an ice been that can be filled from the top. Oh and a single burner and build my smoker into the island somehow.
    The size of the poured concrete is not enough currently. I def. Will need a larger pad. Then I'll fine tune the location and shape.
    I'm starting from scratch building my own frame out of steel studs.
    First things is shape, location and design.... Enjoy the journey..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: outdoor kitchen build in Phoenix, AZ
    Nice! Gonna be a fun journey. Great starting point.
    Welcome to TFP! More info on updating signature and location here .
    Jan 2013
    Friendswood, TX
    320
    Lois like you have a nice area to work with. From the day I started mine to the deal on the concrete was about 6 months. But I enjoy people saying it looks great when they are over without knowing I built it. Also the fact that it turned out a LOT cheaper then using a contractor.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    Good soon to be somewhat blank canvas to work with, the advantage you have is seeing how an island works in the current set up.
    They are moving that thing? wow, good luck!
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
