Results 1 to 7 of 7
Thread: Chlorine
    Apr 2015
    Evesham
    3
    Hi. I joined this forum to try and get some info on a plunge pool I use at a holiday home. It's 10 feet by 3 feet deep. Usually in the summer I arrive. Fill it. Add chlorine and run a pump then monitor level and 2 weeks later I drain it. No probs. however I want to set it up in June then I won't be there for 4 weeks. If I add lots of chlorine and cover it with a dark cover and leave the pump off will the water be clean when I get back ? Thanks. Rob
    38,251
    Re: Chlorine
    Welcome to TFP!!!
    Well first, adding a LOT of chlorine with no regard to the CYA level could damage the pool and equipment.
    Doubtful that it could go 4 weeks with no attention and not have some issues to deal with when you return.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Chlorine
    As Jason says, enough bleach to ensure enough would remain in 4 weeks would bleach out the liner.
    You could improve your odds by ensuring the pool is perfectly balanced and adding an algaecide and letting it mix before covering it up. Avoid anything with copper in it. The recommended one is Poly 60
    oxyethylene(dimethyliminio)ethylene(dimethyliminio)ethylene dichloride 60%
    Apr 2015
    Evesham
    3
    Re: Chlorine
    Ok thanks. Sounds like setting up on arrival is a safer option. I have found that the chlorine levels tend to be a bit on the high side when I test. Is this a major issue for use? Is it ok to rely on just chlorine if it's just set up for a few weeks or do I need to worry about ph and alkalinity?
    So far I've had no issues and the water has remained clear
    Thanks
    38,251
    Re: Chlorine
    You need to worry about the FC level in relation to the CYA level (which is 0 for a fresh fill). The pH, TA, and CH are all likely to be fine, but I would still check and maintain the pH.
    Apr 2015
    Evesham
    3
    Re: Chlorine
    What's fc and cya?
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Chlorine
    Quote Originally Posted by Puyjapin View Post
    What's fc and cya?
    You can learn our lingo here.
