Thread: Pool antifreeze
    Aug 2008
    central kansas
    22
    Pool antifreeze
    The pool store sells 5 star pool antifreeze for $5.00 a gal, the farm supply store sells RV antiffreeze for $3.oo a gal. Both are good to -50f. Will the RV antifreeze mess with my water balance next spring when I open? Should I not use the RV antifreeze?
    20k inground fiberglass
    sand filter
    k-2006 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,170
    Re: Pool antifreeze
    It's the same thing.
    Jul 2008
    Pittsburgh, PA
    118
    Re: Pool antifreeze
    thats a really good price. I think walmart costs more than that.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Montreal Canada
    326
    Re: Pool antifreeze
    Quote Originally Posted by meber
    I've seen two "flavours" of antifreeze up here in Canada anyways, one is alcohol-based (I just can't think of the exact name right now), the other one contains calcium chloride. The LPS sells the calcium chloride one and has a sample of the other one on the counter. The customer thinks he's getting more bang for his buck because the calcium-based one is noticibly heavier.
    I've used the 'regular' alcohol-flavored version* (it does say RV on it) and had no problems with our winter weather sometimes approching -22F. I'm not sure of the effect of adding a calcium based antifreeze on the water balance.
    * In the pool
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Pool antifreeze
    Quote Originally Posted by CaOCl2
    ....I've used the 'regular' alcohol-flavored version* (it does say RV on it) and had no problems with our winter weather sometimes approching -22F. I'm not sure of the effect of adding a calcium based antifreeze on the water balance.
    * In the pool
    HAHAHAHA
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Dec 2007
    Central New York
    504
    Re: Pool antifreeze
    I was at WalMart this morning and saw that the RV anit-freeze is now $4.59 a gal. I paid $3.69 at the same WalMart just 10 days ago. Also, Lowes has the RV anti-freeze for sale at $4.95 a gal.
    I'm glad I got mine at $3.69. I got 22 gals of the stuff.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
