Thread: need to replace liner, where to drain pool water?
    Apr 2015
    Manchester, NH
    6
    Question need to replace liner, where to drain pool water?
    Any words of wisdom? I have to drain about 10,000 gallons of water in order to evaluate/repair a rust hole and replace the liner. thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: need to replace liner, where to drain pool water?
    If you have a waste setting on your filter and city sewer service, you can get enough discharge hose to reach the clean-out on your sewer line and pump the pool water into that. Most cities have regulations against pumping pool water into the storm drains.
    Love TFP? Become a
    TFP Supporter!
    Apr 2015
    Manchester, NH
    6
    Thank you for the reply. I am draining it on to the lawn. It just seems like so much water... I will do it over a few days.
    Letterman
    Above ground, steel wall, 15 x 25 oval 11,000 gallon's, cartridge filter, 2 speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by letterman View Post
    Once upon a time when we had enough rain forecast that I lowered the pool a few inches, I opened the cleanout plug by the kitchen sink drain and shoved the hose in there. I figured a couple thousand gallons would help move the various bits of crud left in the pipes by the dishwasher and the garbage disposal. Initially, I had to reduce the flow a bit so it would stop overflowing, but after a few hours I was able to restore full flow and let it rip. Something to keep in mind.
