Thread: IAqualink 1.0
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    IAqualink 1.0
    I have a schedule setup to run from 8 am to 1 pm everyday.
    I have it setup up to maintain a temp of 85 deg, every 2 hours the pump kicks on to test the water temp, if cold heat pump
    kicks on. What is happening is that when the heat pump reaches the temp it gos into the heat cool down then shuts off. I found the answer from Zodiac cant run that way..
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    38,251
    Re: IAqualink 1.0
    Is there a question here?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: IAqualink 1.0
    I couldnt find a way to delete it, thats why i posted that i found the answer
    Autopilot SWG
