Thread: Thoughts on the recommendations?
    Aug 2014
    Shallotte, NC
    693
    After a somewhat lengthy ******* contest with GLI about their liner warranty. (They wouldn't warranty the liner if improper chemistry was used, but they wouldn't define proper chemistry...) I just noticed that they had added these recommendations to their website:
    pH Daily 7.2 7.6
    Free Chlorine Daily 1.0 2.0 ppm
    Total Alkalinity Weekly 80 120 ppm
    Calcium Hardness Monthly 200 300 ppm
    Stabilizer Monthly 35 60 ppm
    The numbers work from a CSI standpoint, but I suspect they were diddled into submission with a faux CH. Their website incorrectly notes that human tears are pH of 7.4. These numbers vary from TFP thoughts a bit and nothing is mentioned of borates. I can't see FC of 2.0 and CYA of 60 ppm ever ending well. Where (or why) did these numbers come from? Thoughts?
    Re: Thoughts on the recommendations?
    That is similar to, but not the same, as two of the common sets of recommendations that tend to appear. I imagine they simply borrowed it from some other source without any detailed consideration.
