Thread: dirty_steve
    Just wanted to say hello and thanks for all the information. Our pool was finished in late June and I wish I would've found this site earlier. I've learned so much from lurking around other posts and can honestly say that I've gained much more information from a few hours of searching versus what the PB told me. So far no major issues and I'm sure when something does pop up, I will be able to get it resolved quickly from TFP.
    15K gallon gunite pool and spa spillover - medium gray plaster, 2.5HP Hayward pump, Cartridge filter, Goldline Aquarite SWG, Jandy RS8, Polaris 280
    Re: dirty_steve
    Welcome to TFP!
    knowledge is power!! (to quote Schoolhouse Rock...)
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    Re: dirty_steve
    Hey! Welcome to TFP!
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Butterfly's Avatar
    South Carolina
    Re: dirty_steve
    Hi and welcome to the forum!
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    Re: dirty_steve
    Steve, welcome to TFP!!
    I'm VERY happy that your pool has been 'trouble free' - If you ever have a problem, we'll be here for you!
    Luv& Luk
