Results 1 to 11 of 11
Thread: Ceramic tile question
    Mar 2014
    Houston, USA
    5
    Greetings, all! We are about halfway finished with our pool build and came upon a possible issue. I was under the impression that it would be best for ceramic tile to encompass the whole waterline of the pool, but the tile guys just finished and it looks like I have ceramic tile, rock, and veneer at the waterline.
    The PB says it's something he's been doing lately that looks better than the ceramic tile look.
    Any ideas? I thought having the veneer and rocks at the waterline might be an issue in the future...image.jpgimage.jpgimage.jpgimage.jpg
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Ceramic tile question
    I've seen it more and more. We have 6 or 8 rocks at the waterline under our waterfall. They have held up fine for three years so far.
    Welcome to TFP! Nice pics! Please update your signature and location as described here.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Hey Middleseat! I've seen a lot of pictures online of stone at the waterline. Are you using a salt water system? There's tons of debate over the impact of salt on the softer, natural stones. If you are using a SWG, you might do some research to form your own opinion. From what I've read, keeping the water chemicals right is the key. (with any system)
    I think the main purpose of a ceramic or porcelain tile at the water line is for cleaning purposes. It helps disguise (especially lighter tiles) any scum or other build-up, and a shiny or smooth and slick tile makes for easier cleaning than straight plaster or aggregate. But stones? Who scrubs stones? That sounds like a great solution to keeping the waterline nice! Come to think of it, I'm having a devil of a time selecting waterline tile. Maybe I'll switch to stonework!!! Thanks!
    Just want to say, though, I love your choices in materials! You've got that whole natural thing going on beautifully. And your PB using the stones, etc at the waterline extends your theme even better than most tiles. I can't wait to see it all finished. If you can, please post your design and any other pictures, even if from the early build. We're just CRAZY to see pictures of all the build stages. And like Pooldv said, give us your specs! Thanks for sharing! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    It looks great!
    18' x 36' saltwater inground vinyl pool
    Mar 2014
    Houston, USA
    5
    Thanks for the replies so far! My sig has been added... More pics to follow.
    One of the things I was concerned about was the stacked stone veneer being at the waterline. Has anyone had any issues (good or bad)?
    Jul 2009
    Gonzales, La
    220
    Let me ask if the area where the rocks are located was it cut down to add the rocks? Was it planned in with the Gunite spray? I'm thinking the bond beam should have been one level all the way around the pool with the rocks sitting on top of the bond beam. If not there may be some water weeping thru the mortar used to lay the rocks down with.
    Todd
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    The main issue is that there will always be a little calcium buildup just above the waterline. Cleaning this off of tile isn't too bad, but getting it off of stone can be quite a pain due to the uneven surface. This isn't such a big deal in high humidity areas (where evaporation of splashed water is minima), but in Houston I would expect it to be an aesthetic issue after some time goes by.
    Apr 2015
    Houston, Texas
    3,217
    Thanks, Jason, for clearing me up on the cleaning of stone at the waterline. I guess I was thinking it might not show up as much (again, that's what I get for thinking!! LOL!!). I've lived in Houston my adult life since 1977, and it has always seemed pretty humid. I didn't look up any stats on it. Maybe we're a little too far inland to get the benefit of minimal evaporation.
    Funny story for Houstonians: When we visited my in-laws on Cape Cod years ago, my MIL needed her siding repainted, but the painter wouldn't paint if the humidity was 58% or more. We laughed and said no painting would ever happen in Houston if that's what our painters followed! Maybe her painter was just lazy....
    I keep learning from you guys on TFP!! Thanks so much and have a great day! Suz
    TW Pool's Avatar
    Mar 2015
    The Woodlands, Texas
    79
    Middle,
    What is the notched area on the backside of your spa?
    New DIY IG pool in Houston, Texas. 4/30 dig to 6/11 fill. 20' x 42.5' free form pool/raised spa with the following equipment: 3hp Intelliflow pump shared between pool/spa, 120gpm Pentair Waterfall pump, 6' sheer decent, 2 bubblers, 2 large color LEDs in the pool/1 small in the spa, Easytouch 8 with ScreenLogic2, Stenner Pump, auto fill, a 2HP silencer pump for the spa, 850 sq. ft Sundeck, Dolphin Supreme M500 and a TF100+mixer
    Feb 2015
    Bardstown KY
    139
    Beautiful!!!
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    Mar 2014
    Houston, USA
    5
    It's great to see all of the replies so far! We really do have a great community here at TFP...
    The notched area in the spa is for the "power seat" - basically a seat with more jets.
    The area where the rocks are was formed as notches in the gunite stage. I didn't even realize it was a possible seepage issue until you brought it up, 36racin. Thanks! I'll ask my PB about it.
    The calcium on the rocks and stacked stone veneer is a possible issue. I guess I'll have it bead blasted every couple of years instead of every 4-5 to stay on top of the calcium deposits?
    Keep the replies coming!
    2015 build / 25,000 gallon IG free-form plaster (pebble sheen) / 7x7 spa / 420 SF Cartridge Filter / Intelliflo VS pump / TF100 / 400k BTU heater
