Results 1 to 10 of 10
Thread: CYA %99-100?; on the market did Clorox take over? What to look for or stay away from?
    TeamNelson's Avatar
    Feb 2013
    Tucson (Marana) AZ
    48
    The normal stabilizer CYA brand I've bought Kem-Tek looks like it got a shove off the shelf from Clorox products at my home store...
    So now they advertise for pools & spa's (Clorox Pool&Spa 4-lb Stabilizer Pool Balancer) OR another jug for use with SWG... (Clorox Pool and Spa My Salt Pool Saltwater Stabilizer, 5.5 lbs)
    What do I look for to make sure I'm getting the right thing? 99-100% CYA or? I've have all three pool,spa & SWG. I don't know why; I'm just not sold on Clorox being in this market being the sole marketer. I'm not going to step foot into a pool store & nobody can drag me back there.
    Any help to clarify my CYA needs?
    12/2012; 16K Gal. IG PebbleTec, Pool w/Spa attached, Pump Sta-Rite IntelliPro 4speed VS 3050 160gpm, Cartridge Filters Sta-Rite S8M150 450SqFt, Pentair IC60 SWCG, Turbo System 20 In Floor PopUp Heads Cleaner, Zodiac Auto Cover, Pentair EasyTouch 8 Controls & Screen Logic Interface w/APP for phone remote access, InterFab Slide, FiberOptic perimeter lites, TestKit TF100!!! The BEST & the Taylor Speed Stir - A MUST HAVE!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: CYA %99-100?; on the market did Clorox take over? What to look for or stay away f
    Apparently, it's just marketing. They're both the same stuff: 100% Cyanuric acid
    Read the MSDS
    http://cloroxpool.com/sds/80005CLX.pdf
    http://cloroxpool.com/sds/10004CLX.pdf
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    The fine print says cyanuric acid 99% on the kemtech.
    38,301
    Well a SWG requires higher CYA levels ... so I am going to guess that is why they put out a bigger bucket. Kind of weird. Buy which ever is the cheapest per pound.
    TeamNelson's Avatar
    Feb 2013
    Tucson (Marana) AZ
    48
    Thank you all!
    I scratched my head before I found TFP & thanks to all the for this great advice!!!
    Mar 2007
    Murrieta, CA
    215
    FWIW, the guy at Lowe's where I buy my Kem-Tek CYA told me that Clorox had bought out Kem-Tek and was just branding it differently. I have no idea if he was correct.
    As for the change from 4 lbs to 5 lbs, my guess is that it gives them an excuse to raise the price of the bottle, even if the price per pound doesn't change significantly. It means you have to buy 5 lbs whether you need 1 lb or 5. Still cheaper than most pool stores, though.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Mar 2015
    Georgia
    157
    The clorox company doesn't make the pool chemicals and actually kem tek doesnt make their pool chemicals either. If I'm thinking right it is KIK Custom Products that make them. Ever who it is makes several brand names and they just wanted the clorox name on their box because it is familiar with everyone (hence bleach and cleaning supplies). I read this somewhere earlier this year when I noticed Clorox Pool and Spa replaced Aqua Chem at Walmart and Lowes.
    I did notice Clorox Pool and Spa Chlorine Stabilizer states 100% Cyanuric Acid on the bottle so yes that is what your looking for. It is $12.77 for 4 lbs at Walmart. Last year when it was Aqua Chem Stabilizer, it was $13.47 for 3 lbs so it seems clorox is a little cheaper but it's the same thing and probably came through the same factory.
    16k AG Vinyl Sand Filter
    Apr 2015
    Las Vegas Nevada
    1
    Las Vegas Nevada
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I read in Pool and Spa News that it is just Chlorox branding. Chlorox does not make any of it.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    May 2015
    Georgia
    1
    KIK Custom Products has owned BioLab since 2014 (yes the Clorox stuff comes from the same place as all of BioLab's products)
