Results 1 to 7 of 7
Thread: The great 2015 Spring Oak Tree Dump and 9" of Rain.
    May 2014
    Houston, TX
    12
    USING THE TF-100 KIT
    This years Spring dump was very bad due to lots of rain, zillions of leaves, twigs, fuzz, and tons of pollen.
    I don't have time to clean the pool every 2 hours.
    The pool was totally lost. Been fighting for 3 weeks now.
    It has been running 24/7 for 4 weeks with semi daily brush, vac and backwash.
    It has been debree free for 8 days.
    I can't clear up the green powder.
    Last weekend I raised CYA from 20 to 44 and started slamming on Sunday night.
    Every day the green powder returns.
    Tonights readings before brushing.
    CDT 13.5 I dialed it up to 19 Sunday night, dropped to target 17 Wednesday. Just brushed and added 126 oz of fresh 8.25 bleach per pool calc.
    CC .5
    CH 250
    CYA 42 raised from 20 to 44.
    TA 110 was also raised this week from 60.
    PH this is odd and maybe an issue. I did the test and tonight I get 7.2 " my target" I set it aside and do the next test and it now shows 8.2+.
    I never noticed this before, but now this is what happens every time.
    Is this false PH readings?
    I can spend more time on the pool this weekend.
    We may get more heavy rain tonight.
    Any Ideas?
    TF-100 Test Kit. 25 year old plaster in ground, 16,600 gallons pool & spa, sand filter, the worlds oldest Jet Vac pool cleaner. Pool is surrounded and covered be large live oak trees.
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Re: The great 2015 Spring Oak Tree Dump and 9" of Rain.
    Your pH will read false in the presence of high chlorine, so once you lower pH to acceptable levels to begin the SLAM, you don't check it again until your chlorine drops below 10. Anything above 10 won't test properly.
    When you say green powder, is it algae or is it from your trees?
    Also, are you keeping the chlorine above shock level for your CYA 24/7, as best as possible?
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    PH will test false with a FC over 10 so............that could be the problem.
    How often are you able to test and add chlorine a day?
    I wonder if you vacuumed to waste instead of to the filter if that would help get rid of the "powder"? It might be worth a try.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It has been a very busy spring, I've been struggling to stay ahead of it all too.
    May 2014
    Houston, TX
    12
    When I say green powder I mean algae, When you brush it looks like green powder on the bottom.
    My slam target is 16. 2 hours after last nights treatment I was at 19.5 We had more rain last night.
    At 11 this morning the water looks like pea soup- much worse than last night can't see the bottom. CL is now 18.5 with almost no cc.
    I have been at 16 or above for most of 6 days with no improvement? How can the algae be thriving?
    I am so desperate I may go blow $80 on some phos free.
    Any ideas?
    Jul 2012
    Tallahassee, FL
    30,579
    light fixture or ladder? Other side of the skimmer door? have you scrubbed those areas?
    Kim
    DFW, TX
    24,502
    Skip the phosfree. I would up the chlorine target to 20 to see if that helps. And bring the FC up to 20 every few hours.
