Thread: 2010 Hotspring Vanguard.....mystery
    Apr 2015
    SC
    2
    Greetings all,
    So I am doing some maintenance on my tub. I do a drain, clean filters, clean tub and change out a dual moto massage unit that went bad. The moto massage unit was very easy to replace, followed directions no problem.
    I fill tub and turn it back on, no problem there. It heats back up fine, and I take a soak in it that evening. All is well.
    The next day I go to get in and water has dropped about 6 inches, I think ok maybe an "air lock" that caused water to drop. I fill it up and soak later that evening. Two days go by and I go for a soak and open cover and all but 10 inches of water have leaked out. The funny thing is there in no water on ground any where coming from under tub, no wet spot, nothing. I fill back up and open access cover while running, no leaks, no wet foam, nadda.
    Anyone have any ideas?
    Robert
    Leesville, SC
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: 2010 Hotspring Vanguard.....mystery
    Hi, welcome to TFP! How do you usually drain your tub?
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP! The mystery of the day! Is it on a concrete slab? Last time I drained my tub I didn't put the drain cap back on the drain hose tight enough. But, there was some water on the deck!
    Apr 2015
    SC
    2
    Thank you for the welcome,
    I always open main drain at bottom of service panel. That was the first place I looked, double checked. Its sits on a brick paver patio beside my deck.
