Thread: Questions and clarification installing Hayward through the wall skimmer
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Arrow Questions and clarification installing Hayward through the wall skimmer
    I ordered a Hayward through the wall skimmer as I cannot stand the over the wall Intex surface skimmer.
    I understand how to cut the hole and everything. My confusion comes as to how to hook it up. Do I just hook it directly to my pump and just ignore the strainer outlet that is hooked to my pump now? Or do I have to figure out a way to T the stainer outlet to the skimmer and then to the pump? We hare not hard plumed. I know I will have to get a ball valve to block water from coming out strainer outlet if we eliminate its use. I have watched videos as well as read through threads on here.
    Thanks and grateful for any input.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Questions and clarification installing Hayward through the wall skimmer
    I think either way is fine. If you tee then you don't have to worry quite as much about maintaining minimum water level to feed water in the skimmer.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by pooldv View Post
    Thanks. I will be working on this next week probably. Just wanted to get an idea before I do it.
    Lisa
    Jul 2014
    Oakbank, Canada
    389
    There is topics for this listed under "useful links", I am sure you will find the info there. Tons of folks posted about installing a thru wall skimmer. You tube is your friend as well for that, just search for it.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    DFW, TX
    24,450
    Wow, here is everything you ever wanted know!
    http://www.troublefreepool.com/threa...ex-Pool-Owners
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thanks!
    I really which the pics showed up in the link.
    Lisa
