Thread: after ike
    after ike
    We survived Ike and are on generator power. I have cleaned up most of the leaves in the pool and have some chlorine in at basic levels. We have no pumps but I do have a generator. Is there anybody in the Cypress, TX area 290\Cypress Rosehill who has a electric pool robot I can use or rent to clean my pool bottom? Of course my Polaris wont work without the pumps. Thanks. Please e-mail me at gregg@ggcoatings.com . Thanks
    25,000 gallon freeform inground gunite pool with 12" raised spa. 3.5'- 6.4' deep.
    2 skimmers, 6 returns and bubbler on sunshelf.
    Jandy 1.5 hp pump, Jandy valves, Jandy CL340 cart filter, Jandy Aquapure 1400 SWG, Polaris 280 w booster, Jandy LXI 4000 heater.
    White plaster, flagstone coping, custom tan tiles with decos on raised spa.
    Pentair lights.
    650 sq ft concrete deck.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: after ike
    Hey, glad you survived. Due to my recent electrical fire, I have my pool pump running on a generator. You can put a cap on the cord to your pump and plug it is. (Provided its wired for 110) Unless your genny has a 220 output and your pump is wired 220. Mine runs fine on the genny and I can vacuum it normally.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Jul 2008
    Arkansas
    20
    Re: after ike
    Our pool survived Ike but the roof did not. I was a little worried the pool was going to end up in my house. I'm not in the Texas area or I would loan you a cleaner. I spent the better part of the evening cleaning leaves myself. Good luck.
    Ballparkmom
    16 x 33 x 52" AG pool, Hayward Vari-flo pump & sand filter, 1 skimmer, 1 main drain, 1 return, Zodiac LM3 24,000 SWG, Pool Rover Jr., 2 kids & a million toys
    Re: after ike
    Electricity is not my strong point. The pumps are wired up to the main box at the house. Thanks GD we have a generator. Many in Houston/ Galveston are without. We lost some shingles but thats it. The pool is still clear and blue. I put the floater in and got as many leaves out as possible. Would love a robot. I guess we can count our blessings if my only problem is a dirty pool and no a/c. We are 50 miles from Galveston and go there often. That city is about wiped off the map.
    Pentair lights.
    Re: after ike
    got the pool bottom clean. Friend had a water hose operated vacuum that did a great job. Need to get one like that. He uses it for his spa. Put it on the pool pole, hook the water hose up and it creates a vacuum into a sand and silt type bag.
    Pentair lights.
