Results 1 to 17 of 17
Thread: Had lots of leaves on bottom
    May 2012
    Dallas, Texas
    47
    Pool doesn't seem to be getting clear. 2 weeks in and can't see bottom.
    FC 10 to 16 depending on time of day.
    TA 80
    CYA 25
    PH 7.0
    Pool was uncovered thru fall and winter and had lots of leaves on bottom. No chlorine was added over winter. Removed most of the leaves with vacuum. There are still a few leaves that come to the surface when brushing. I'm wondering if the filter is working properly, it hasn't had maintenance since new in May 2012. We run it 24/7 and backwash 2 times daily. Will it help to do a deep clean on the filter or should I just be patient and wait. I have creepy crawly, should I use it for vacuum to waste by moving it around where I want it to go?
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Help with SLAMing - pool is a swamp
    Is CYA 25? or 65? With CYA of 65 you should be maintaining FC of 26. Which would explain why you are not making progress if you are keeping FC at 10 to 16.
    May 2012
    Dallas, Texas
    47
    The black dot on CYA test disappears between 20 and 30. I'm guessing it's about 25. I'm chlorinating based on 30. I am loosing about 6 ppm chlorine daily. I bring it up to 16 ppm in the evening and by the next evening it is at 10ppm. I am unable to test during the day.
    TF 100 Test Kit
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    for some reason Toomchfun hijacked the OP (bbingraham's) thread instead of starting his own. this would explain the confusion
    Now split off into it's own topic. JasonLion
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    DFW, TX
    24,516
    Re: Had lots of leaves on bottom
    Ok, I'm all caught up now. The slam will go better and faster if you can maintain your FC at shock level or a little above. How about adding chlorine in the morning and the evening? I would just keep filtering and backwashing but not deep clean yet. And patience, too.
    May 2012
    Dallas, Texas
    47
    Thanks, I'll add chlorine morning and night.
    I added Borax to bring up the PH, should I add CYA or just wait until the water is clear?
    P.S. sorry about the hijack, I wasn't sure of the protocol.
    TF 100 Test Kit
    DFW, TX
    24,516
    No, don't add cya. Adding cya will just mean you have to maintain higher chlorine levels.
    No worries on hijacking, mods need something to do.
    Apr 2015
    Quinlan, tx
    811
    I couldn't test during the day during the week either and had similar problems. I tested and added bleach before work, after work, and before bed. On the weekends, I added bleach as often as possible, setting a timer for every two hours when I was home. I also used skimmer socks for the first time. Stick with it. I also worried about the filter, etc not doing its job. It just takes patience and consistency. You can do it and it's worth the effort!
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    SLAM process takes lots of patience! You will get there.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2012
    Dallas, Texas
    47
    I added chlorine last night to bring it up to 15.5ppm
    This morning's readings were:
    FC 12
    CC 1
    PH 7.7
    TA 90
    CYA somewhere around 25 to 30 the dot disappeared after 30 and before to top of the of the test with a Taylor K-2006.
    I'll use 30 for shock level and keep it up today. Going to brush now.
    TF 100 Test Kit
    DFW, TX
    24,516
    Good plan!
    May 2012
    Dallas, Texas
    47
    I started SLAM last Saturday 4-25-15 and one week after SLAM began, pool is still quite cloudy. I kept the SLAM levels up all day Saturday, and thru the week and brushed all but three days this. I vacuumed two of the three days I didn't brush. I'm adding 3 to 4 bottles 8.25% bleach daily to keep levels up.
    Last Night FC was at 13.5 this morning the FC was at 12.5. 1ppm loss overnight.
    I added chlorine this morning 8:00 am to bring my level up to 15.5 and at 2:00pm FC is 9.5
    Current readings:
    FC 9.5
    pH 7.2
    TA 90
    CYA less than 25. the black dot does not disappear at the top of the tube.
    TF 100 Test Kit
    May 2012
    Dallas, Texas
    47
    At what point should I bring CYA up to the recommended level? I really can't tell what my CYA level is, the black dot doesn't disappear on the Taylor 2006 test. Will bringing it up slow my chlorine loss? I am currently losing 7-10 ppm daily, depending on sunlight.
    TF 100 Test Kit
    DFW, TX
    24,516
    You can add 10-15ppm of CYA in a sock now. Yes, it will help slow loss due to sunlight. But, you will also need to increase you shock value.
    May 2012
    Dallas, Texas
    47
    Update:
    Water is clear!
    Current Levels:
    FC 3
    CC is less than .5
    PH 7.6
    TA 100
    CYA 40
    CH 100
    I am noticing what appears to be filter sand gathering in crevices on the bottom of the pool within a few hours after vacuuming. What causes that? Is there a solution? Also, How long should I run the filter daily?
    TF 100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I run mine sun up to sundown, but sometimes I run it 24/7.
    Did you pass the OLCT?
    Lisa
    May 2012
    Dallas, Texas
    47
    yes, it passes the OLCT. Chlorine lose is less than 1ppm.
    TF 100 Test Kit
