Thread: Hard Plumbing Intex
    Hard Plumbing Intex
    Just going to breifly explain my setup, Ive got a 15ft frame pool with a intex sand filter and an air source heat pump. Now obviously im fine using the intex plumbing until I need to connect the filter outlet to the heater. Ive currently made some very basic (and quite useless) adapters out of some of these and bathroom sealant to minimise leaking...
    My makeshift adapters have been in use for 2 years, the first year they were fine, but last year they were leaking, its nearly time to get the pool out again and I'm looking for something a bit more reliable.
    Ive searched through some previous threads on here for more info but a lot of them contain loads of pictures which no longer show.
    Im in the UK as well so not sure where I can get parts I need.
    Any help is appreciated
    Oct 2012
    Central Ohio
    180
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    jmcdtucson's Avatar
    Jun 2014
    317
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Apr 2015
    Bristol
    5
    Re: Hard Plumbing Intex
    Has anyone found where to get these box/conduit adapters in the UK?. I bought some at screwfix but they don't fit.
    Also anyone tried this?
    http://www.worldofpools.com/rigid-pi...ue-details.htm
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Apr 2015
    Bristol
    5
