Thread: Mounting outdoor wireless transceiver
    Dec 2014
    Riverside California
    482
    I will be installing the same transceiver. The most convenient place for me to mount the unit would be on the side of the plastic enclosure that contained my old Compool LX-10 (now upgraded to Easy Touch). The receiver will be in a room next to the enclosure, about 12 feet from the transceiver and through a drywall/stucco wall. Being that my link distance is very short, I wonder if the power electrical circuits in my plastic enclosure would interfere with the signal. Any thoughts before I do this install? I could install a metal plate which is grounded between the enclosure and the transceiver if interference becomes an issue.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Re: Mounting outdoor wireless transceiver
    Because of the short distance between the transmitter and receiver you should be fine.
    Dec 2014
    482
    Thank you, JasonLion. That will save me from having to trench through the maze of stuff under my enclosure.
