Thread: Adding Borates
    Mar 2015
    Lebanon, PA
    79
    Adding Borates
    Let me start by saying this will be my first season using the TFP methods. I have checked my CYA in advance of opening the pool and i will need to let out some water and put new in (about 10,000 gal) to bring my CYA level down. So if i am adding borates would i do the next or SLAM the pool 1st? Also any risk of Borates with a Plaster pool?
    Located in Lebanon,Pennsylvania.. 25,000 Gallon IG Plaster Pool Installed Fall of 2011...
    Stenner 3GPD pump
    Jandy DEV60 60SqFt DE Filter (Using Puri fiber.)..,1.5Hp Jandy Pump PMPH1.5
    Aqucal SQ 166R Heater...Polaris 9400 Robot/Cleaner
    TF-100 Test Kit
    38,290
    Re: Adding Borates
    You want everything in your pool to be balanced and well maintained before adding the optional borates.
    Re: Adding Borates
    Borates are fine with plaster except during the first 30 days after plaster is freshly applied.
    As jblizzle said, wait until you have the water replaced, SLAM complete, and everything going smoothly before adding borates.
