Thread: Confirm boric acid amount
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Am I correct for a goal of 50 ppm in a 20500 gal pool I need 50 lbs of boric acid? I will be starting with a new liner and water. Or are borates naturally present?
    18' x 38' 20,500 gallon vinyl IGP, 3.5 - 7' depth, Pentair FNS Plus DE filter,
    2hp Whisperflo high performance pump, 1.1hp boost-rite pump for the cleaner,
    250k BTU MasterTemp heater, LetroLegend pool cleaner, Hayward TurboCell GLX-CELL-15 chlorine generator
    Speedstir, K-1776, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Borates - Why and How
    I come up with 49lbs, so yes. No, borates are not naturally present, if you haven't added any then there aren't any borates in your pool.
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Re: Confirm boric acid amount
    Thanks pooldv, I'm new to the do it myself pool care, some things just look too easy and I wanted to be sure.
    Ernie
    DFW, TX
    24,502
    Right on! It is easy and seemed a little too easy when I started too. No worries, keep asking until you've got it all figured out. Your crystal clear water will convince you.
