Thread: Ah darn! Nature2 causing my stains?
    Apr 2015
    Lancaster, Ca
    17
    When I bought my house the pool had a nature2 mineral cartridge, it also came with light blue /green stains along with strange blotches throughout the the entire pools plaster. Not knowing the cartridge could be the problem I've replace with new ones the last 2 years. Yup the stains are worse than before. Is there a way to remove the stains short of draining?
    Thanks or any help.
    9k gallon IG rectangle plaster pool spa combo, Sta-Rite P4R6F3-188 1 1/2 hp pump with Schneider Electric AVT11HU41M2U variable speed motor drive for 2 speeds, Sta-Rite System 3 cartridge filter, Sta-Rite SR400NA gas heater, Jandy AquaLink RS, Zodiac Baracuda G3 cleaner Cover-Pools T-3 automatic cover. Built in 2006. K-2006 test kit.
    38,275
    Re: Ah ****! Nature2 causing my stains?
    You will need to do an ascorbic acid treatment and then put metal sequestrants in the water.
    See: http://www.troublefreepool.com/conte...d-metal-stains
    Apr 2015
    Lancaster, Ca
    17
    Re: Ah darn! Nature2 causing my stains?
    Okay. So vitamin C is a way to test the stains. I'll get get some on my next trip to the store. Now what's my next step if the vitamin C does nothing?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Dsanchez737 View Post
    Do you have a chlorine tablet? If the vit C doesn't take it off, try setting a tricolor tablet on it.
    But, as you have been using Nature 2 I'm betting the vit C will do the trick.
    Support the site
    Apr 2015
    Lancaster, Ca
    17
    Thanks I'll give it a shot.
