Thread: Pump replacement
    Jun 2014
    Pine Mountain GA
    2
    Pump replacement
    I've learned tons over the past year after purchasing a home with an existing pool. I've been able to solve many pool related issues while enjoying the pool. Unfortunately, the kids crashed a bicycle into the pool pumps / PVC piping yesterday requiring yet more work. Fortunately, all damage was to the pool hardware and not the kid. Having said that, all visible damage is to the PVC piping. The first break is where the PVC threads into the pump head. I see no visible cracks on the pump. The second break is where the booster connects to the PVC. My concern is the age of the pump & motor. If I start monkeying with the pump to get the PVC out, the ABS pump could be cracked. Additionally, I'd like to explore the option of upgrading to a VS pump from the OLD single speed. My question here is do I still need a booster pump for the Polaris cleaner? And, If I upgrade to a VS pump, should I invest into a better controller/timer over the analog timer I currently have. It works but doesn't keep correct time.
    Thanks
    16x32 IG vinyl 24K gal, Hayward S210T Sand filter, Hayward 1HP Super pump, Polaris PB4-60 booster
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump replacement
    It's salvageable, but will take some effort. You have several possibilities, chip out, or use a screwdriver and mallet and attempt to unscrew the piece. Purchase a new pump. (If you go that route get a 2-speed.) Replace the housing and transfer everything over.
    Depending on your energy cost. A 2-speed is a better value. No need to replace the timer. Just a simple toggle switch.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    If you get a VS Pump you can either ditch the timer or wire it to the timer and leave it ON all the time. The control panel on the pump can control the pump run times and speeds. My Pentair VS pump is wired to a timer that is ON with no dogs on the clock.
    Jun 2014
    Pine Mountain GA
    2
    Well, Maybe I'll tinker with the pump a little before just replacing it. Most of my incentive to replace the existing pump with a VS is related to my power tier. Just trying to do all I can do to lower power consumption.
    Thanks for the information.
