Thread: Green Pool....Is this ok?
    May 2011
    State College,PA
    10
    Hi all,
    We have a 15x30 AGP, 13000 gal. We had our cover rip this year in February and dumped some leaves etc. into it. It still covered most of the pool but finally, the cover was removed in late March, early April. My question basically is this. The water, of course, is slowly turning green and my wife wants to dump a gallon or two of chlorine bleach into the pool to combat that. I'm assuming that's ok? Technically we use Pristine Blue/chlorine shock but I'm wondering if this is the good time to switch to the TPC method. I didn't want to technically open the pool yet because of the temps being too cold and possible freezing weather. Wondering if we should let it run it's course until the freezing weather is passing or just dump in the chlorine.
    15x30 AG, 13000 gal
    Sand Filter 22", 1.5hp, Flow/backwash rate 55 gpm
    38,271
    Re: Green Pool....Is this ok?
    It was a good time to switch away from the Blue to TFP before you ever started. That stuff is too expensive and not effective.
    We recommend opening before the water temperature rises above 60 degrees. What is your temp?
    We do not recommend blindly adding any chemicals without using test results to know the proper dosages. Adding a few bottles here and there is a good way to not accomplish what you want and to waste money. Either open the pool and start clearing it up by following the ShockLevelAndMAINTAIN Process, or ignore it and deal with the bigger mess (by following the ShockLevelAndMAINTAIN Process) down the road.
    Either way you need one of the Recommended Test Kits.
    Smykowski's Avatar
    Sep 2011
    3,065
    We never advocate "dumping" anything into the pool. TFP is all about understanding what you add to the pool and why. If you want to do it our way, you will have plenty of people who want to help you succeed.
    Take a look at Pool School, and start with the article in my signature, and let us know if we can help you take the proverbial plunge.
    Casey's Avatar
    SW PA
    10,428
    It's time to open the pool in Pennsylvania. I open in April every year. Yes, it's cold but I'm running my pump tonight to keep from freezing, as I did last night. If you're going to switch, do it now. Order a test kit like the TF100. You won't regret it.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Casey View Post
    I agree with Casey on the TF-100 test kit. I also recommend you ad the X large to your order as I have learned the process does take time. It will not happen over night. I have been slamming since last Saturday. I am getting closer. I tested every 2 hours in the beginning. Yesterday and today I have allowed more time to go by. SLAM requires patience, but if you follow what these people say you will see improvements each day. Good luck
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
